• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Color changes when saving from PSD to JPEG
New Here ,
Aug 27, 2016 Aug 27, 2016
Hi all,
When i export the image bellow from psd to jpeg the color changes.
The pink becomes purple!
Any help would be appreciated
Views
81.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 28, 2016 Aug 28, 2016
Just to be absolutely clear on this - the problem here is that the file is in ProPhoto RGB.
Windows "Photos" is not color managed and cannot represent a ProPhoto file correctly. Nor will any other application without color management.
Convert to sRGB. That is the correct answer to your question (which is a very common beginner's mistake, BTW).
In Photoshop, go to Edit > Convert to Profile > sRGB IEC61966-2.1.
If you are Using "Export As" or "Save For Web", just check the Convert to sRGB box.
Votes
Translate
Translate
Adobe
Community Expert ,
You need to know more about bit depth, Color space and Color management
your psd is 16-bit .. so when exporting to jpg , the image previewer could not preview the 16-bit  correctly
Switch to 8-bit and make sure your color space is the same as the
image -> mode -> 8 bit
more about color management:
Set up color management
Votes
Translate
Translate
Report
Report
Community Expert ,
Jun 05, 2022 Jun 05, 2022
Hi Mohammad,
actually this is, unfortunately, not a bit depth issue but a colourspace issue.
I hope this helps
neil barstow, colourmanagement net :: adobe forum volunteer:: co-author: 'getting colour right'
google me "neil barstow colourmanagement" for lots of free articles on colour management
Votes
Translate
Translate
Report
Report
New Here ,
Nov 13, 2023 Nov 13, 2023
LATEST
Why did his answer then finally solve the issue for me?
I converted to sRGB before saving, while saving whatsoever it never worked. I got suspicious when i saved as webp which supports 16bit and it worked. So pretty much, it seems a depth issue and not a color space issue.
Votes
Translate
Translate
Report
Report
Community Expert ,
Convert to sRGB.
Your original is ProPhoto, which only displays correctly in a fully color managed environment.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Yes, i did that and worked.
Thank you very much.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 14, 2020 Sep 14, 2020
Hi, I had converted profile to sRGB and 8 bits/channel. Still when I take the pictures on my phone, the color changes. But on the other hand when I take a screenshot via snipping tool, and take that image on my phone the image is what I can see on screen. So definitely I'm going wrong somewhere while exporting but don't know where. Any other suggestions?
Votes
Translate
Translate
Report
Report
New Here ,
Aug 07, 2023 Aug 07, 2023
Facing the same issue
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 08, 2023 Aug 08, 2023
When exporting both Convert to sRGB and Embed the color profile.
Dave.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 07, 2021 Mar 07, 2021
Hopefuly helpful to others. This worked for me too.
But the second way below to solve did not,
"If you are Using "Export As" or "Save For Web", just check the Convert to sRGB box."
Though ti's 2021 and I'm still using Photoshop CS5.
Votes
Translate
Translate
Report
Report
Community Expert ,
You must Convert to sRGB and Embed Color Profile.
For accurate colour put Windows Photos away and use color managed software and browsers
Dave
Votes
Translate
Translate
Report
Report
Community Expert ,
Tin16B8
Yes convert to sRGB AND embed the profile
I hope this helps
Votes
Translate
Translate
Report
Report
Community Beginner ,
Apr 06, 2021 Apr 06, 2021
hi guys i want to ask for help, in my case is the other way i edit the photo in adobe rgb then i follow the steps i convert to srgb then export also change to 8 bit  and when i open the picture is over saturated, i dont know what happens, yesterday i purchased a beutiful 4k monitor for editing because i wanted to represent the color correctly but its terrible now, its dcip3 and 90% color gamut, but can you please help me recommend what to do, i follow the steps here and the steps in videos but all the videos in photoshop looks great and when they export it looks bad so it doesnt apply to me. Thanks in advance. Capture.JPG
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 07, 2021 Apr 07, 2021
There is a very simple answer to your question, and it can be summed up like this:
If you don't fully understand the implications of buying a wide gamut monitor, don't buy one. Wide gamut monitors can only be used with fully color managed software.
Yes, DCI-P3 is wide gamut. And no, Windows "Photos" is not color managed. Stop using it, it will not display correctly, ever.
There is no problem using wide gamut monitors if you understand what they do. I have been using wide gamut monitors exclusively for many, many years and it's perfectly fine and usable for any purpose. You just cannot use software that doesn't support color management. Or if you absolutely have to, ignore the oversaturation.
Votes
Translate
Translate
Report
Report
i think is too late for the understanding because i already purchase it.  I will stop using the photos app in windows, thank you for the advise
Votes
Translate
Translate
Report
Report
New Here ,
Oct 27, 2019 Oct 27, 2019
Not sure if this is scientifically correct, but when I print photos from my Samsung 8 into online albums or home printer, they print dull. When I print photos from my Nikon 5200 or other Nikon cameras the color comes out true to what I see on my screen. Printing online with different companies is tricky...but I never resolved that issue with print media. So now, when taking photos I want to print, I use my bulky, less convenient Nikons. Correct me if I'm wrong, but I think there is a tech difference between what we see on our phone/computer screens and what we print on papers. Printing is complex and frustrating but I've been doing it for decades. There is backlight on screens. There is no backlight on paper...so the colors are muddy. You could try a different profile in Photoshop for messing with photos for print. That doesn't change the light in print photos for me. I have never printed directly from my phone to my printer to see if that prints true, but then I can't use photoshop and dicker with it. My problem might be that way back when my techy refused to set me up with Apple due to cost and other issues like it crashed all the time, and I got used to PC and it's cost effective for me. He came free. Maybe if you have a home printer you could experiment using different profiles in Photoshop with camera pics and phone pics. One album I did, I had a mix  of photos from phone and Nikon...from a trip and I noticed a consistent muddiness from my phone pics compared to the sharp true color from the Nikon. I like to travel with phone for pics...my Nikon is a pain re charging batteries overseas and carrying the heavy stuff...but next time I'm taking phone for phone and Nikon for photos!!! Good luck with printing. It's complex.
Votes
Translate
Translate
Report
Report
Community Expert ,
Printing is not complex and a good match from screen to print is achievable (within the obvious limitations of inks). But it requires :
a. A calibrated and profiled screen (a phone screen is not calibrated or profiled)
b. Software which uses colour management (guess what - neither iOS or Android support colour management). Photoshop is colour managed
c. Documents having an embedded profile that matches their content (this can be sRGB, Adobe RGB, Pro Photo etc)
d. A printer profile which describes your printer + ink + paper combination.
You do not experiment with colour profiles , you use the right one for the device or document it describes.
With those four in place, printing is simple
Dave
Votes
Translate
Translate
Report
Report
New Here ,
Jan 19, 2020 Jan 19, 2020
I am experiencing the same problem. When I copy and paste or "place" my photoshop images into the InDesign document, which is a booklet I will have printed, these images are much lighter, less saturated and even appear pixellated.  The solution, as I understand it, lies in color management and that I should convert to the "sRGB 1966"...that is mentioned in this thread and other ones as well. BUT I believe the print company wants the images in CMYK. Or is this outdated info? thank you very much!
Votes
Translate
Translate
Report
Report
Community Expert ,
Save out as RGB from Photoshop, and make sure the color profile is embedded when you save the file. For the purposes of this discussion it doesn't matter which profile, as long as it's there.
Make sure the InDesign color settings preserve embedded RGB profiles. By default it will, so don't change any settings here unless you know what you're doing. The images will now match Photoshop.
If the printer wants CMYK, they want what is known as a press-ready PDF. You export this PDF from InDesign, and this is where everything is converted to final destination CMYK. Here's the important thing: you must always ask the printer which CMYK they want, which specific CMYK profile you should use. There is no worldwide standard here and the Photoshop/InDesign default is probably wrong! The default, US Web Coated (SWOP), is not used anywhere outside the Americas, and isn't always inside either.
InDesign can handle both RGB and CMYK content in the same document. Images should always be placed as RGB, while graphic elements are usually best created in final destination CMYK.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 21, 2020 Jan 21, 2020
Thank you...we are learning...slowly! One thing we discovered is that the photoshopped images we were having trouble with had not yet been "linked" into our InDesign document. When we did that, that got rid of the pixelation. We are also seeing a difference in image appearance between our main computer and the new laptop. (Same document is on both) On the laptop, (HP Windows 10) the Photoshop images appear to much better match the exported InDesign images in color hue and saturation. However there's still a discrepancy between the two on our Lenovo Windows 10 desktop computer. We will follow your instructions per above.  Thank you,
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 22, 2020 Jan 22, 2020
Hi Mary
you wrote: We are also seeing a difference in image appearance between our main computer and the new laptop. (Same document is on both) On the laptop, (HP Windows 10)
Display screens need calibration and profiling, For this you need a measurememnt device and good software.
Adobe applications will then use the screens ICC profile to send adapted data to the monitor screen to produce correct appearance.
you may notice, though, that tilting a laptop screen or m=ving your head uop and down can give significant changes to on-screen appearance, so - how can we know - which positiion is right?
That "feature" of many laptopo screens can mean that for serious image judgement use you may have a hard time using the laptop screen. In whiuch case you need to plug in a decent second screen like an Eizo Coloredge - some of those are even self calibrating and make their own ICC profile.
have a read up here about what icc profiles do:
https://www.colourmanagement.net/advice/about-icc-colour-profiles/
I hope this helps
if so, please "like" my reply
thanks
neil barstow, colourmanagement.net
[please do not use the reply button on a message in the thread, only use the one at the top of the page, to maintain chronological order]
Votes
Translate
Translate
Report
Report
Oct 05, 2020 Oct 05, 2020
I have the same issue but the answer is not working.Untitled-1.jpgUntitled-5.jpg
Votes
Translate
Translate
Report
Report
Community Expert ,
@sus4mee  No that is not the same issue.
It looks like your "issue" is that you are seeing a change in your image when flattening. The answer is to view before and after flattening at 100% zoom.
The preview when zoomed out is not accurate. In most images it is close enough that it goes unnoticed but on some, with fine noise or certain combinations of blending, it is very noticeable indeed.
So adjust your image at 100% zoom and the flattened version will look the same.
Dave
Votes
Translate
Translate
Report
Report
@davescm
Thank you for your kind reply. But it is sure that it is not about Zoom, I think. Coz I checked in a different view, even in 200% to make sure.
Votes
Translate
Translate
Report
Report
