10 Replies Latest reply on Sep 3, 2017 11:53 AM by TroyAllenSr
    CFMAIL Stripping Spaces in Release 2016
    charlesp36266952 Level 1
      We recently upgraded to ColdFusion 2016 having run ColdFusion for over a decade.  Most everything has gone well except a weird issue with email.  Every CFMAIL function now strips out spaces when displaying multiple variables in a row.
      For example, many automated reports that generated output through CFMAIL have something like this in the code:
      Example Query:
      <cfquery name="GetUsers" datasource="database">
           Select User_Name_F, User_Name_L
           From Users
           Where Active = 1
           Order By User_Name_L, User_Name_F
      Output Code (in body of CFMAIL tag):
      <cfoutput>#GetUsers.User_Name_F# #GetUsers.User_Name_L#</cfoutput>
      Output Result (in multiple email clients):
      Before the upgrade this displayed as "John Doe" correctly with the space between names and has for years.  I can force a blank space by hard-coding it in, which I shouldn't have to do.  I can also do a "Select (User_Name_F + ' ' + User_Name_L) as name" and make it work, but many times I will use the first and last names in different orders in the same output, so I shouldn't have to do this either.  The same issue occurs from queries from MySQL 5 and Microsoft SQL Server.  The same issue occurs with variables from queries as well as variables created using CFSET.
      Is this a bug?  What am I missing?
