• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Replacing a Style or Paragraph Tag with Another
New Here ,
Aug 28, 2016 Aug 28, 2016
I am trying to find the API to set the style in RoboHelp Script. In the Clean Project Example (as in the following code snippet), it shows how to find a undefined style and remove that style. In this case, instead of token.removeAttribute("style"), is it possible to set a style, for example, a paragraph tag, say "body". Also, is it possible to find a paragraph tag, say "Normal", and replace it with "body" paragraph tag.
if(token.tokenType == RoboHelp.TokenType.TOKENTAG)
//Does this token have style attribute?
if(token.getAttribute("style") != "")
//This token has a style attribute. Now remove the style attribute.
token.removeAttribute("style");
Thanks.
Views
181
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Aug 29, 2016 Aug 29, 2016
LATEST
You want to set a style name? In that case: (note: I didn't run/test this, but it should at least point in the right direction)
if(token.tokenType == RoboHelp.TokenType.TOKENTAG && token.hasAttribute("style") == true) {
   token.setAttribute("class","myStyleName");
The above will assign the class 'myStyleName'. You'll, of course, want to check the type of tag and whether you need to assign the style.
Something that I have been having fun with: you'll have to save before closing the TokenManager. Otherwise you'll be wondering why the script won't work. Embaressed to say I've forgotten this more than once...
tokens.save();//Save changes
tokens.close();//Close the TokenManager or you'll run out of memory
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
