12 Replies Latest reply on Sep 14, 2016 5:23 AM by tpk1982
    Deleting tab separated column content
    tpk1982 Level 4
      I am trying to remove content of a particular column in a table. But it is not working if i used the set up like below. The highlighted texts are not removed (under product). Not sure why. Please help to sort out.
      Tried coding:
      var para=app.selection[0];
      var myColumn=prompt("Enter column number to delete","");
      if(myColumn){
      var lines=para.contents.split('\r');
      var no_of_lines = lines.length;
      for(i = 1; i <= no_of_lines; i++)
      var x = lines[i-1].split('\t');
      app.findGrepPreferences = null;
      app.changeGrepPreferences = null;
      app.findGrepPreferences.findWhat=x[myColumn-1];
      app.changeGrepPreferences.changeTo  ="";
      para.changeGrep();
      K
        • 1. Re: Deleting tab separated column content
          Obi-wan Kenobi Level 5
          • 2. Re: Deleting tab separated column content
            tpk1982 Level 4
            Thank you Obi.
            But when i run the script it show object is invalid error in line 25
            • 3. Re: Deleting tab separated column content
              Kai Rübsamen Level 4
              If you use the grep-search, you must escpape '(' >> '\(', but since your findWhat is clear, you could also use the text search!
              Try this one:
              var curSel = app.selection[0];
              var myColumn = prompt("Enter column number to delete","");
              if (!myColumn) exit();
              var allParas = curSel.paragraphs.everyItem().getElements();
              app.findTextPreferences = app.changeTextPreferences = null;
              for (var i = allParas.length-1; i >= 0; i--) {
                  var curPara = allParas[i];
                  var curParaContents = curPara.contents;
                  var x = curParaContents.split("\t");
                  app.findTextPreferences.findWhat = x[myColumn-1];
                  app.changeTextPreferences.changeTo  ="";
                  curPara.changeText();
              • 4. Re: Deleting tab separated column content
                tpk1982 Level 4
                Awesome.. thank you Kai
                • 5. Re: Deleting tab separated column content
                  tpk1982 Level 4
                  If i delete the last column, it deleted the return marks too.. may i know why?
                  • 6. Re: Deleting tab separated column content
                    You can test this in the estk with the console!
                    Choose first 5 and then 6. If the return is included, the Pipe-symbol is in the next line
                    var f = x[myColumn-1];
                    $.writeln(f + "  |");
                    • 7. Re: Deleting tab separated column content
                      Kaï,
                      Cool! Nice code for me to be carefully studied // Thanks for my learning!
                      The script only deletes the contents!
                      Would be cool to have a variant that entirely removes the column [as I want in my script (that doesn't work (?) // The grep code is OK!].
                      • 8. Re: Deleting tab separated column content
                        You can solve this problem, by deleting the return from the 'findWhat' string, e.g.
                        app.doScript(main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "remove tab column");
                        function main() {
                        if (!(app.selection.length == 1 && app.selection[0].hasOwnProperty("baseline"))) return;
                        if (!myColumn) return;
                          var f = x[myColumn-1].replace("\r","");
                          app.findTextPreferences.findWhat = f;
                        Notice also, that line 18 will throw an error, if you e.g. have 6 columns and enter in the prompt-dialog 7 or if you input is not an integer. So you should check this as well. ;-)
                        • 9. Re: Deleting tab separated column content
                          Aha! Right!
                          I've found the error and corrected in other topic!
                          • 10. Re: Deleting tab separated column content
                            tpk1982 Level 4
                            HI Kai,
                            Sorry to reinitiate this thread. But found one small problem. It is working fine if i have all column and rows content. If some thins missing then it throws error.
                            app.doScript(main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "remove tab co lumn");          function main() {
                                  if (isNaN(myColumn)) {
                                      alert("Please enter Number only");
                                      return;
                                for (var i = 0; i <allParas.length; i++) {
                                if (myColumn>x.length){
                                      alert("Selected table contains only "+x.length+" columns"+". Enter only in between "+x.length);
                                      return;
                            alert("Column deleted successfully");
                            app.findTextPreferences = app.changeTextPreferences = null;  }
                            Is it possible how to ignore this?
                            Regards,
                            K
                            • 11. Re: Deleting tab separated column content
                              The problem is, that those columns are not really empty, because of you xml-dots. So the easiest way is, to use try/catch for the fc-operation:
                              try {
                              catch (e) {};
