5 Replies Latest reply on Aug 29, 2016 12:51 PM by kglad
    JSFL Convert Lines to Fill
    gregmax34
      Just like the title says, I'm writing a script that I want to convert all lines in the library to fill.
      Every time I do try to call it, I get an error "Error: The function convertLinesToFills() is currently unavailable."
      Any reason why?
        • 1. Re: JSFL Convert Lines to Fill
          are you selecting an object and then using:
          fl.getDocumentDOM().convertLinesToFills()
          • 2. Re: JSFL Convert Lines to Fill
            gregmax34 Level 1
            Yep, sure am. I have done some more digging and found out that the shape object had vector lines, because calling convertLinestoFills without breaking apart would cause function is unavailable error. So I had to break that element apart. And breaking things apart wasn't easy either. I had to lock all the layers except the layer and frame I want to edit and then call break apart.
            However, it still doesn't apart to convert the lines to fills.
            This is what I'm doing:
            if ( member.isDrawingObject )
                var tl = dom.getTimeline();
                for ( var i = 0; i < tl.layers.length; i++ )
                    tl.layers[i].locked = i !== currentLayer;
                tl.currentFrame = currentFrame; //
                tl.currentLayer = currentLayer;
                 dom.selectAll(); // WHY must I select everything? seems a bit scary
                // dom.selection = [member]; // THIS is what I want!
                dom.breakApart();
                dom.convertLinesToFills(); // still not working
                dom.selectNone();
            • 3. Re: JSFL Convert Lines to Fill
              the first problematic line i see is,
              which should probably be deleted.
              though this doesn't look right, either:
              what are you trying to do with that line of code?
              • 4. Re: JSFL Convert Lines to Fill
                gregmax34 Level 1
                That line of code is not the problem from what I understand from this: The function breakApart() is currently unavailable!?
                I need to lock all layers except the one I want to break apart.
                • 5. Re: JSFL Convert Lines to Fill
                  what's that line of code supposed to be doing?
