Why does the Adobe PDFMaker Plugin not show up in any of the Office applications after installing O365?
I've tried removing and reinstalling the plugin - no change
Tried activating the plugin and also checking the Load Value in the registry
Tried repairing Office and Adobe Pro XI
I found this solution and looked into it but the string for the PDF Plugin did not show up in the registry for Office 2013
https://forums.adobe.com/thread/1555265
This is what I see:
[cid:image002.png@01D2045D.0412B450]
This MS Blog entry might help:
https://blogs.msdn.microsoft.com/haahmadi/2010/05/26/my-office-addin-does-not-load/
Steve,
I’ve tried this as well and the load behavior shows ‘3’ .
I even tried removing the add-in to reinstall it and now it will not reinstall
Did you check the Resiliency key?
I will check that but any idea why the plugin is not showing up in the list of Addins?
What are your EXACT versions of Office and of Acrobat?
Office 2013 and Adobe Standard XI vs 11.0.17
Thanks for that. I've checked Compatible web browsers and PDFMaker applications and it seems to be expected to work. I have no further suggestions myself.
This is what I see:
