1 Reply Latest reply on Aug 30, 2016 6:06 PM by benjamino96587917
    Code Sign error: No matching provisioning profile found
    sameerk97134981
      Hi, I am having problem while building iOS app which I build successfully 2 months ago. I have tried changing phonegap versions from config.xml.
      When I try to build my app using Phonegap Build, It shows "Oh geez. Your build failed. Sorry, but a problem occurred on the build server"
      and when I go to log. I can see
      Build settings from command line:
        ARCHS = armv7 arm64
        CONFIGURATION_BUILD_DIR = /tmp/gimlet/1222944/project/build
        CORDOVALIB = /tmp/gimlet/1222944/project/CordovaLib
        ENABLE_BITCODE = false
        ONLY_ACTIVE_ARCH = NO
        OTHER_CODE_SIGN_FLAGS = --keychain /tmp/gimlet/1222944/secure.keychain
        PROVISIONING_PROFILE = e763bf04-36d2-4b7f-9097-5076b5aab301
      === BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH THE DEFAULT CONFIGURATION (Release) ===
      But I didn't mention any PROVISIONING_PROFILE with such UUID. In the last of the log it shows
      Check dependencies
      Code Sign error: No matching provisioning profile found: Your build settings specify a provisioning profile with the UUID “e763bf04-36d2-4b7f-9097-5076b5aab301”, however, no such provisioning profile was found.
      ** BUILD FAILED **
      Any help will be appreciated. Thanks in advance.
