8 Replies Latest reply on Sep 1, 2016 1:02 PM by Silly-V
    RegExp for multiple search items?
    subieguy2 Level 3
      So I am wanting to find a part number in a document. There could be several part numbers. Thanks to some of the users here I have code that currently looks like this....
      #target illustrator
      function changeData() {
          function processDoc(doc) {
              // OLD PART NUMBER
              var oldPart = /111-1111/gi;
              // NEW PART NUMBER
              var replacePart = "111-1111",
                  result;
              var allText = doc.textFrames;
              // SEARCH AND CHANGE LOOP FOR PART #
              while (result = oldPart.exec(allText[i].contents)) {
                  try {
                      aCon = allText[i].characters[result.index];
                      aCon.length = result[0].length;
                      aCon.contents = replacePart;
                  } catch (e) {};
              // SCAN THRU ALL OPEN DOCUMENTS
              for (var i = 0; i < app.documents.length; i++) {
                  app.documents[i].activate();
                  processDoc(app.activeDocument);
        changeData();
      Now please excuse my lack of knowledge but I was wondering if it is possible to do a list search and list change. I know this isn't the syntax to use but just to get the point across....
      // OLD PART NUMBER
      var oldPart = /111-1111 || 222-2222 || 333-3333/gi;
      // NEW PART NUMBER
      var replacePart = "444-4444 || 555-555 || 666-6666", result;
      So if part 111-1111 is found it would change it to 444-4444. if part 222-2222 is found it would change it to 555-5555. if part 333-3333 is found it would change it to 666-6666.
      Can anyone explain how to do this within my function??
      Thanks in advance!
        • 1. Re: RegExp for multiple search items?
          Silly-V Adobe Community Professional
          Looks like you can just put your old part numbers and new ones into 2 arrays and go through them.
          • 2. Re: RegExp for multiple search items?
            subieguy2 Level 3
            Ok so how do you apply an array to a regexp?
            • 3. Re: RegExp for multiple search items?
              subieguy2 Level 3
              Ok so I understand how to search for multiple items in a regexp...but how do i make it match to an array position for the new part or results???
              #target illustrator
                      // OLD PART NUMBER
                      var oldPart = /111-1111|222-2222|333-3333/gi;
                      // NEW PART NUMBER
                      var replacePart = "111-1111", result;
                          try {
                          } catch (e) {};
              changeData();
              • 4. Re: RegExp for multiple search items?
                Just use a simple array and make the 'process all documents' loop be inside of a loop that goes through your array of items to replace.
                var replaceThese = ["111-1111", "222-2222"];
                var withThese = ["333-3333", "555-5555"];
                for(var i=0; i<replaceThese.length; i++){
                     for (var j = 0; j < app.documents.length; j++) {
                       app.documents[j].activate();
                       processDoc(app.activeDocument, replaceThese[i], withThese[i]);
                Of course you will have to modify your processDoc function to accept the replacee with the replacer as 2 additional arguments.
                • 5. Re: RegExp for multiple search items?
                  subieguy2 Level 3
                  I understand what you are saying and thank you for that. However I guess I didn't give all the information....sorry about that.
                  The part number I am looking to replace is within a sentence (meaning it isn't in a text frame by itself).
                  Plus I also need to keep the formatting.
                  Here is an example of what the document would contain.
                  PART NUMBER: 111-1111, CHANGE: 05, VERSION: -    (All of that is in one text frame)
                  PART NUMBER: 222-2222, CHANGE: 01, VERSION: HE   (All of that is in one text frame)
                  Both of the above text frames could be on one document....or could be on separate documents.
                  • 6. Re: RegExp for multiple search items?
                    Ya so you would need to change up your processDoc function to go something like this:
                        function processDoc(doc, oldTxt, newTxt) {
                            // OLD PART NUMBER
                            var oldPart = new RegExp(oldTxt, "gi");
                            // NEW PART NUMBER
                            var replacePart = newTxt, result;
                    • 7. Re: RegExp for multiple search items?
                      subieguy2 Level 3
                      I'm sorry Silly-V.... I appreciate your help but this is more advanced than I know how to put together. I'm new to regexp and I don't usually do functions.... lol
                      So basically what I am saying is I am a graphic designer and suck at programming.
                      • 8. Re: RegExp for multiple search items?
                        Don't worry you don't suck, you can do it, you have the awesome powers of greatness and you can overcome any obstacle!
