3 Replies Latest reply on Sep 1, 2016 9:54 AM by Vikram_k1810
    Invalid command 'JkIPRestrictionFile'
    susong
      RedHat 7.2
      httpd-2.4.6-40.el7_2.4.x86_64
      ColdFusion 11 (64-bit)
      After installing hotfix 8, apache is not starting:
      Aug 30 16:08:27 web5vm httpd[2843]: AH00526: Syntax error on line 6 of /etc/httpd/conf/mod_jk.conf:
      Aug 30 16:08:27 web5vm httpd[2843]: Invalid command 'JKIPRestrictionFile', perhaps misspelled or defined by a module not included in the server configuration
      Anyone experiencing this issue?
        • 1. Re: Invalid command 'JkIPRestrictionFile'
          Vikram_k1810 Adobe Employee
          Hi Su,
          Have you tried recreating the connectors after installing the update? We have removed the IPRestrictions file in CF11 Update 3 and above. It must be defined in the Apache Web Server end in case your environment requires its use, but not on the ColdFusion end. I would suggest you to try recreating the connectors and see if this helps.
          Vikram
          • 2. Re: Invalid command 'JkIPRestrictionFile'
            suy54188317
            That worked great, Thank you.
            This is how I recreated apache connection, let me know if there's anything I missed?
            1. Backup mod_jk.conf file and /opt/coldfusion11/config/wsconfig/ directory
            2. Remove mod_jk.conf file and /opt/coldfusion11/config/wsconfig/ directory
            3. Run wsconfig, here is the specific command I used:
            /opt/coldfusion11/cfusion/runtime/bin/wsconfig -ws Apache -dir /etc/httpd/conf/ -cfide /opt/coldfusion11/cfusion/wwwroot/CFIDE/ -bin /usr/sbin/httpd -script /usr/sbin/apachectl
            4. Additionally, had to change the file context for mod_jk.log file for selinux to allow access
            chcon -v --reference=/var/log/httpd/access_log /opt/coldfusion11/config/wsconfig/1/mod_jk.log
            • 3. Re: Invalid command 'JkIPRestrictionFile'
              Hi Su,
              It looks good to me.
              Vikram
