11 Replies Latest reply on Oct 5, 2018 8:03 AM by danpreston
    Character Animator- using pre-recorded talking head
    regnaD_kciN Level 1
      How can I use a pre-recorded (green screen or not?) talking head to trigger my puppet?
        • 1. Re: Character Animator- using pre-recorded talking head
          KJerryK MVP & Adobe Community Professional
          If you want to use a video file in place of a live camera, try webcam software, like ManyCam. I've found it to work very well. Ch doesn't see any difference between that and a camera.
          • 2. Re: Character Animator- using pre-recorded talking head
            oksamurai Employee Moderator
            Here's a video tutorial on Manycam someone did a while back:
            • 3. Re: Character Animator- using pre-recorded talking head
              regnaD_kciN Level 1
              Adobe depending on a third party app in order to read/import media?  That sounds outside of their play anything model!
              • 4. Re: Character Animator- using pre-recorded talking head
                We might eventually integrate built-in functionality for this, but it's not a very common user request so it's currently low on the priority chain. But I'll add your voice to the list of supporters!
                • 5. Re: Character Animator- using pre-recorded talking head
                  regnaD_kciN Level 1
                  "not a very common user request so it's currently low on the priority chain."  With a video, talking head, import feature, Character Animator's uses will become unlimited!  Nearly all of Adobe's products have this feature.  This would be the biggest BangForTheBuck capability you could incorporate!
                  • 6. Re: Character Animator- using pre-recorded talking head
                    I hear you! By the way, I remembered there is another way to do this:
                    To generate face data from prerecorded video:
                    • 1. In After Effects CC 2015, extract face measurements data from the video, as follows:
                      • a. Import the video footage into a composition.
                      • b. Draw a closed mask around the face, open the Tracker panel, then set Method to Face Tracking.
                      • c. Click the Analyze buttons to track the mask to the face.
                      • d. Set the current time indicator to the frame representing the rest pose for the face, then click Set Rest Pose.
                      • e. Click Extract & Copy Face Measurements.
                    • 2. In Character Animator, select the puppet with both the Face behavior and its Camera Input parameters armed for record.
                    • 3. Place the current time indicator (playhead) at the frame matching the first Face Measurements keyframe in After Effects.
                    • 4. Choose Edit > Paste. The face measurements data on the system clipboard is converted to a Camera Input take on the selected puppet.
                    Hopefully that helps.
                    In reality, I think this can often sound better than it really is a lot of times, at least in my limited experience. For example, if I took a scene from a movie or TV show or political speech, I'd need to make sure I have a long single camera scene with the speaker's face big and prominent and well lit enough and head on, without background faces that may pull away from the main one. For these kind of things I just take the voice and do Timeline > Compute Lip Sync From Scene Audio to get the correct mouth animations, and then I can record my own performance take by take over top of that (so if I just wanted to focus on the eyes, or head movements, etc - I can do that).
                    The green screen example as shown in the video above feels like a better use case, where you have one actor in an optimal CH environment (big face, solid background, good lighting) doing the voice and face tracking. But still, the more I use CH, the more I prefer to "build up" performances - just focusing on individual parts and blending takes until I get something perfect.
                    3 people found this helpful
                    • 7. Re: Character Animator- using pre-recorded talking head
                      MasterMatt111 Level 1
                      This is helpful, but having an option to import pre-recorded video to track would help a lot. I'm working on a project where my actor is remote and will be sending me videos of himself on webcam. In this sense it will be exactly like a webcam video, just pre-recorded.
                      • 8. Re: Character Animator- using pre-recorded talking head
                        STUDIOMT
                        I think it could be a very usefull feature to have the ability to import video too (in state of only using webcam)
                        Exemple : When you are editing a project, a voice over could be record in another studio (in another language for ex.), if they record video too, you could easy animate your caracter.
                        • 9. Re: Character Animator- using pre-recorded talking head
                          Koepchen Level 1
                          I also think it would be great to have the feature of being able to import pre-recorded footage instead of having to record it live. So, here is another user whom you can count on the list of supporters so that hopely one day not too far distant in the future you will incorporate this feature.
                          Thanks and with kind regards, Christian!
                          • 10. Re: Character Animator- using pre-recorded talking head
                            brennanm22220420 Level 1
                            Thank you for this workaround, it was very helpful. However, I would like to add my voice to the requests for a built-in solution to this issue. This workaround does not work for my machine for clips longer than 30 seconds -- it simply takes too much to try to copy and extract the face measurements. Being able to turn a pre-recorded video into an animation is a very useful ability at least in my work, where we are able to record in the required conditions, but are not always able to have Character Animator at the time.
                            • 11. Re: Character Animator- using pre-recorded talking head
                              danpreston Level 1
                              Adding my voice to those requesting built-in capability in Character Animator to extract face data from pre-recorded video ... understanding all the caveats about the quality of the video being used. Thanks for the continued development of a great piece of software, and for engaging with and responding to the user community!
