5 Replies Latest reply on Sep 2, 2016 4:50 AM by cbishop01
    Side by side Checkboxes question.
    cbishop01 Level 2
      I knew how to do this on my other script but its been changed so much that i dont know where to start.  How can i place these checkboxes side by side to have 2 rows instead of 1 long row? the FULL script is here minus the addition below How to make this check box Apply to all Documents?
        w.tabs[1]= w.tabGroup.add ('group');
        w.tabs[1].add('statictext {text: "Select a change to make"}');
        w.tabs[1].add ('panel');
      with(w.tabs[1])
      var p1 = w.tabs[1].add('panel {text: "CHANGES", preferredSize: [-1, 100],orientation: "column",alignChildren: ["left","Center"]}');
        new CBX ( p1, 'APPLY TO ALL DOCUMENTS', false, cb1CallBack );
        new CBX ( p1, 'Find and Replace', false, cb2CallBack );
        new CBX ( p1, 'RQ and Bigger GHS Running Changes English / Spanish / French', false, cb3CallBack );
        new CBX ( p1, 'RP and Smaller GHS Running Changes English / Spanish', false, cb4CallBack );
        new CBX ( p1, '5 Galon weight Statement change to 18.924 Liters', false, cb5CallBack );
      //Start of ListBox
      var Pan1=w.tabs[1].add ('panel {text: "GHS!!", preferredSize: [-1, 100],orientation: "column",alignChildren: ["left","Center"]}');
       And the search string i'm trying is.
      myResult = w.show();
      function cb1CallBack() {
          if(myResult == 1 && (cb1CallBack.value==true)){
                  Replace_TXT(" <CR> ", "^p");
                  Replace_TXT(" <CR>", "^p");
                  Replace_TXT("  ", " ");
                  Replace_TXT(" :", ":");
                  Replace_TXT(" .", ".");
                  Replace_TXT("^p^p", "^p");
          function cb2CallBack() {}
          function cb3CallBack() {}
          function cb4CallBack() {}
          function cb5CallBack() {}
          function cb6CallBack() {}
          function cb7CallBack() {}
          function cb8CallBack() {}
          function cb9CallBack() {}
          function cb10CallBack() {}
          function Replace_TXT(input, output)
          app.findChangeTextOptions.caseSensitive = true;
          app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
          app.findTextPreferences.findWhat = input;
          app.changeTextPreferences.changeTo = output;
          app.documents[0].changeText();
          main();
      Thanks in advance.
