1 Reply Latest reply on Sep 1, 2016 6:50 AM by kglad
    Flash Pro CS5.5 compatibility with Windows 10
    stacep75180077
      After installing windows 10, my Flash Professional CS5.5 did not launch anymore and asked to uninstall and re-install the product.
      I re-installed from my original CD.
      After installation under Windows 10, the programs runs and I can open my FLA files, but exporting to AVI is very flawed.
      The installation ended with the following errors:
      Exit Code: 6
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 8 error(s), 10 warning(s)
      WARNING: DW066: OS requirements not met for {0D96CFE6-376D-44B8-808A-16F3BEB73263}
      WARNING: DW066: OS requirements not met for {EE85C227-0148-4825-B659-6A1E142571EE}
      WARNING: DW066: OS requirements not met for {6BC81374-1E33-4495-93E2-DD2B10D358EE}
      WARNING: DW066: OS requirements not met for {23E445D5-FD83-4C50-A211-EB26A2975317}
      WARNING: DW066: OS requirements not met for {D97AF04B-B70A-4862-BC25-31E6D9C4A529}
      WARNING: DW066: OS requirements not met for {2EA9B52E-8613-41A0-9EEF-FF54AD4CC810}
      WARNING: DW066: OS requirements not met for {970C9F3A-39C5-480B-BE51-7C70AB9F84DB}
      WARNING: DW066: OS requirements not met for {E348E466-429A-4FB0-AFCF-8306C16BBFF1}
      ----------- Payload: {2EE4F060-CEE6-4002-AA8B-91B791541767} Pixel Bender Toolkit 2.6.0.0 -----------
      WARNING: DF035: CreateAlias:Icon file does not exist at C:\Program Files (x86)\Adobe\Adobe Utilities - CS5.5\Pixel Bender Toolkit 2.6\windows\pb_app.icofile:\\\C:\PIXELB~1\source\winwood\Staging    0X1.CE7989P-1016rea\windows\pb_app.ico42178f80493091e8e552c84a2897e9da68fce32_32_f8049309 1e8e552c84a2897e9da68fce for icon C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe\Adobe Pixel Bender Toolkit 2.6.lnk with target C:\Program Files (x86)\Adobe\Adobe Utilities - CS5.5\Pixel Bender Toolkit 2.6\Pixel Bender Toolkit.exe(Seq 89)
      ----------- Payload: {7202D4A7-F7E6-4e7a-B77D-7B1C4E8B5CA6} Adobe Flash Player 10 ActiveX 10.0.0.0 -----------
      ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Stace\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
      ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
      MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Stace\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
      ----------- Payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 2.0.0.0 -----------
      WARNING: DF029: ARKServiceControl::StartService: Service not started/stopped SwitchBoard. Current State: 0 Exit Code: 0 Service Specific Exit Code: 0(Seq 1)
      ----------- Payload: {D97AF04B-B70A-4862-BC25-31E6D9C4A529} Adobe Flash CS5.5 11.5.0.0 -----------
      ERROR: DR012: Setting Registry Value Failed. Error 5 Access is denied.(Seq 154)
      ----------- Payload: {43A1C48E-3E50-410e-951C-E17A66BBF824} Adobe Flash Player 10 Plugin 10.0.0.0 -----------
      ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Stace\AppData\Local\Temp\InstallPlugin.exe, command: -install plugin -msi
      MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Stace\AppData\Local\Temp\InstallPlugin.exe, command: -install plugin -msi
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Adobe Flash Player 10 Plugin: Install failed
      ERROR: DW050:  - Adobe Flash Player 10 ActiveX: Install failed
