1 Reply Latest reply on Sep 2, 2016 7:01 AM by Bruce Bullis
    Adding metadata to custom Metadata Schema
    Kelly Anderson Level 1
      Hi Bruce,
      I see you've added the ability to add a metadata property to the Project Metadata Schema and populate it with data.  (Thank you!!)
      Any work on being able to do this on a custom Metadata Schema?
        • 1. Re: Adding metadata to custom Metadata Schema
          Bruce Bullis Adobe Employee
          If that schema is installed in the Right Place™, and enabled in the "Metadata Display..." UI, then it might work today. [If not, your test code could feature prominently in a bug I'd write, on that behavior...]
          Unlike Prelude, PPro doesn't import dynamic schemae embedded in XMP assets. But if the .xml is in the Right Place™, it'll be available for a user to enable. Annoying: there's currently no way to programmatically enable custom schemae; we're looking into enabling (valid, present) schemae by default in future versions.
