20 Replies Latest reply on Oct 24, 2016 6:26 AM by Three Feathers
    File not found
    Three Feathers
      In coldfusion-out.log I'm getting this message: Error [ajp-bio-8012-exec-3] - File not found:....
      The file in question does not exist. It has been deleted from the site structure for a while now.
      Why am I getting this message?
        • 1. Re: File not found
          BKBK Adobe Community Professional & MVP
          That is actually what Coldfusion is saying. Your code might still be referring to the deleted file. The other log files should tell you where to look.
          • 2. Re: File not found
            Three Feathers Level 1
            I searched the entire site for links to the page[s] in question and found none.
            The lines in the log are repeating every 0 to 4 minutes.
            What other log files are you referring to?
            • 3. Re: File not found
              WolfShade Level 4
              Is there a chance that the URL to the file in question could be bookmarked?  If so, you're probably seeing people trying to access the file from a bookmark, who don't know that the file is no longer there.  Just a thought.
              V/r,
              ^_^
              • 4. Re: File not found
                WolfShade Level 4
                I just thought of something.  If the link is directly to the file, then it will just error out.  However, if you are using CF to link to the file, you can check if the file exists, first, and redirect to an error page if the file doesn't exist, letting people know that the file is no longer available.
                HTH,
                ^_^
                • 5. Re: File not found
                  exception.log
                  application.log
                  server.log
                  A scheduled task perhaps? A request in onSessionStart or onApplicationStart?
                  • 6. Re: File not found
                    If it wasn't repeating so frequently, I would consider this. But this is repeating anywhere from zero seconds to about four minutes - 24/7. There are other pages in this log: all ColdFusion.
                    The exception log is giving me: coldfusion.runtime.TemplateNotFoundException
                    The application log gives repeating error: "Error","ajp-bio-8012-exec-36","09/06/16","15:11:17",,"File not found: " The two numbers after 'exec'- change.
                    Server log has no errors.
                    This particular problem seems to have started on 8/10/16 @ 2:43 pm.
                    My exception and application logs do not go back that far. Server log has no entries for that day.
                    • 7. Re: File not found
                      We're not using an application file and there is nothing scheduled in ColdFusion server.
                      • 8. Re: File not found
                        If I understand it correctly, this error is occurring continuously, without any interference from you. If so, then it is probably a bug.
                        I also think we should now go back to basics. What is your set-up:
                        Operating System
                        Coldfusion version
                        Web server
                        Location of your current working directory in the file system
                        Could you please show us the error messages in full, including all the stack trace.
                        There is something you could do in the meantime. Open the Coldfusion Administrator. Go to the Caching page.
                        Uncheck the option Cache template in request
                        Uncheck the option Save class files
                        Press, in turn, each of the buttons that enable you to clear the cache
                        Press the button to Submit Changes
                        • 9. Re: File not found
                          WolfShade Level 4
                          Ah.. template not found is a bit different from file not found.  I was under the impression that this was a download issue.  I think BKBK is spot on with the bit about CFAdmin and clearing the cache, especially if there have been any .cfm files recently deleted.
                          Or has this started after an upgrade?
                          V/r,
                          ^_^
                          • 10. Re: File not found
                            Windows Server 2008 R2 Datacenter Service Pack 1 - last update 8/1/16
                            IIS 7
                            ColdFusion 10 - update 15 - 12/26/14
                              16 - 21 available
                            CMS: Percussion 5.3.0
                            File Directory: http://www.massasoit.edu/academics/library/
                            One sub-directory only: library/voices-of-the-archive
                            [active home page] http://www.massasoit.edu/academics/library/index
                            Files not found:
                            /academics/library/getting-started/electronic-resources/alphabetical/index.cfm
                            and
                            /academics/library/getting-started/electronic-resources/subject/index.cfm
                            exception.log:
                            "Error","ajp-bio-8012-exec-89","09/07/16","10:23:33",,"File not found: /academics/library/getting-started/electronic-resources/alphabetical/index.cfm The specific sequence of files included or processed is: C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\alphabetica l\index.cfm'' "
                            coldfusion.runtime.TemplateNotFoundException: File not found: /academics/library/getting-started/electronic-resources/alphabetical/index.cfm
                              at coldfusion.filter.PathFilter.invoke(PathFilter.java:115)
                              at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
                              at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
                              at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
                              at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:58)
                              at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
                              at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
                              at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
                              at coldfusion.CfmServlet.service(CfmServlet.java:219)
                              at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
                              at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:303)
                              at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
                              at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
                              at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
                              at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:241)
                              at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
                              at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
                              at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
                              at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
                              at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
                              at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
                              at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
                              at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:422)
                              at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:199)
                              at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.jav a:607)
                              at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
                              at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
                              at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
                              at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
                              at java.lang.Thread.run(Thread.java:722)
                            application.log:
                            "Error","ajp-bio-8012-exec-87","09/07/16","10:24:05",,"File not found: /academics/library/getting-started/electronic-resources/subject/index.cfm The specific sequence of files included or processed is: C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\subject\ind ex.cfm'' "
                            "Error","ajp-bio-8012-exec-87","09/07/16","10:24:06",,"File not found: /academics/library/getting-started/electronic-resources/alphabetical/index.cfm The specific sequence of files included or processed is: C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\alphabetica l\index.cfm'' "
                            coldfusion-out.log:
                            Sep 7, 2016 10:24:05 AM Error [ajp-bio-8012-exec-87] - File not found: /academics/library/getting-started/electronic-resources/subject/index.cfm The specific sequence of files included or processed is: C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\subject\ind ex.cfm''
                            Sep 7, 2016 10:24:06 AM Error [ajp-bio-8012-exec-87] - File not found: /academics/library/getting-started/electronic-resources/alphabetical/index.cfm The specific sequence of files included or processed is: C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\alphabetica l\index.cfm''
                            I did the caching page suggestions and error is still coming.
                            • 11. Re: File not found
                              WolfShade Level 4
                              I hate to sound condescending, but I have to ask:  Did you restart CF services, or reboot the server, after the changes?
                              V/r,
                              ^_^
                              • 12. Re: File not found
                                WolfShade Level 4
                                One more thing:  You state that there is only one sub-directory "/voices-of-the-archive".  But the missing files are under "/getting-started".  Was this whole getting-started folder removed, recently?
                                V/r,
                                ^_^
                                • 13. Re: File not found
                                  Getting Started directory was removed 8/10/16. Same day as errors started.
                                  • 14. Re: File not found
                                    I did not restart. There was no mention of that. I will when I can
                                    • 15. Re: File not found
                                      ColdFusion restart did not stop the errors.
                                      • 16. Re: File not found
                                        WolfShade Level 4
                                        I just saw your message #7; how can you run this without an application.cfc or application.cfm???
                                        Did you use Windows Explorer to search the files for the missing template name?  Or did you use something like DreamWeaver or Eclipse to do the string search?  If you used Explorer, it's not surprising that it wasn't found.
                                        Just musing:  The filename has to exist in the code, somewhere.  You've turned off template caching and restarted the CF service, so it most likely (99%) isn't that.  The only other thing that I can think of, I already mentioned - that someone is using a bookmark to try to access the document.
                                        Is this all coming from the same IP address?  If not, then you're probably looking at some kind of 'bot, trying to spider your site, not knowing that the /getting-started folder no longer exists.
                                        V/r,
                                        ^_^
                                        • 17. Re: File not found
                                          Hi Three Feathers, the cause of the error is clear. Your application requests the file C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\alphabetica l\index.cfm, but is unable to find it. In fact, you confirm you had deleted all the files in the directory C:\inetpub\wwwroot\CM1\academics\library\getting-started\.
                                          Why did you delete the directory? Is it possible to put the directory (and its contents) back?
                                          Suppose, for whatever reason, you cannot return the getting-started directory. As a last resort, you could do the following:
                                          1) Create the directories
                                          C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\alphabetical \
                                          2) Create a file called Application.cfc and place it in directory, electronic-resources. Contents of file:
                                          <cfcomponent displayname="Application file for electronic-resources">
                                          <cfscript>
                                          this.name = "electronicResources";
                                          this.applicationTimeout = "#createTimespan(2,0,0,0)#";
                                          this.loginStorage = "session";
                                          this.sessionManagement = "true";
                                          this.sessionTimeout = "#createTimeSpan(0,0,30,0)#";
                                          this.setClientCookies = "true";
                                          this.scriptProtect = "all";
                                          </cfscript>
                                          </cfcomponent>
                                          3) Place an empty file, which you name index.cfm, in the directory \alphabetical\ and in the directory \subject\.
                                          Observe the logs. Let us know what happens.
                                          • 18. Re: File not found
                                            Hello. I’m back. External audits tend to change priorities.
                                            I applied your instructions below. I now get:
                                            "Error","ajp-bio-8012-exec-2","10/21/16","10:55:19","alphaSubj","Datasource library_ms could not be found. The specific sequence of files included or processed is: C:\inetpub\wwwroot\CM1\academics\library\getting-started\electronic-resources\alphabetica l\index.cfm, line: 245 "
                                            This particular data source was disconnected 9/1/16.
                                            Thank you,
                                            • 19. Re: File not found
                                              Then you know what you have to do: create the datasource library_ms in the Coldfusion Administrator.
                                              • 20. Re: File not found
                                                Thank you BKBK. I still don't understand why it was happening, but all those error messages have stopped.
                                                Thank you again for your help,
                                                'TF'
