2 Replies Latest reply on Sep 2, 2016 5:57 AM by karthiks94217840
    Duplicate XML Element - label and caption
    karthiks94217840 Level 2
      Dear Friends,
      I need your help
      How to duplicate XML Element for label and caption text?
      My need: Example below:
      Label >> Table A2.8 >> skip A2.8 >> A2.8-separate text (just alert)
      Caption >> Hellow work >> Hellow work-separate text (just alert)
      Table A2.8. Hellow Word
      (to)
      A2.8. Hellow Word >> (separate text frame) Duplicate XML Element.
      This is possible to script? i don't how to start and end. Please suggest friends. I have place the screenshot below:
       var tableTableCapXpath = "//jrnlTblBlock/p[@aid:pstyle='jrnlTblCaption']/bold/label"; //Duplicate label part
       var tableXMLElementCap = curDoc.xmlElements[0].evaluateXPathExpression(tableTableCapXpath);
       var tableTableCapXpath = "//jrnlTblBlock/p[@aid:pstyle='jrnlTblCaption']"; //Duplicate caption part
      Please help and suggest friends
      Thanks in Advance
      KS
        • 1. Re: Duplicate XML Element - label and caption
          Loic.Aigon Adobe Community Professional
          Not sure what you want to do exactly but xpath won't duplicate a xmlElement because it let you just target the nodes you are interested in.
          However EvaluateXPathExpression will return an array of XMLElements if any is found.
          var myXMLElements = someXMLElement.evaluateXPathExpression( someXPath ); //array of XMLElements objects
          In the latter, you can reference a member of that array and call a regular duplicate method.
          var sourceXMLElement = myXMLElements[0]; //A reference to the first child of the array
          then duplicate
          var dup = sourceXMLElement.duplicate();
          It will copy the xmlElement just after the source so you may want to move the copy somewhere else;
          dup.move ( LocationOptions.AFTER, someReferenceXMLElement );
          FWIW
          Loic
          http://www.ozalto.com/
          • 2. Re: Duplicate XML Element - label and caption
            Hi Loic,
            Thanks to your reply! and good suggestions Thanks.
            KS
