3 Replies Latest reply on Sep 9, 2016 11:17 AM by Flórián Mézes
    Text disappears by online publishing used Publish Online, version 2015.4
    Flórián Mézes Level 1
      Hallo,
      I’ve created an InDesign document that contains text too, and then published it online using the Publish Online version 2015.4. The texts are in all conceivable formats, i.e. info text, animated text or button text with OTF or TTF fonts in plain or backgrounded text frame etc, excluding texts inserted with HTML tool.
      The result:
      – all the texts (including all texts and text frames that function as info, animation or button with OTF or TTF fonts in plain or backgrounded frame etc) appear only from the third Publish Online page onwards; that is, all texts disappear on the first two pages (text frames, animations, buttons etc also),
      – however, in the thumbnail navigation bar all the texts appear on all pages as they should,
      – other objects appeared nice in Publish online document and in the pdf generated from it, too.
      These symptoms are just the same when I use Publish Online through pdf export.
      Whatever I alter in InDesign preferences, these symptoms are unchanged.
      All texts work nice on all pages when I publish the document directly from InDesign to epub, swf and pdf, too.
      Texts inserted with HTML tool work always, too.
      How I can resolve this problem, thanks for help,
      -mf-
      the Publish Online appear variants:
      first distext page (all text in thumbnail bar), document page 1
      second distext page (all text in thumbnail bar), document page 2
      and the first page appeared full text, document page 3
        • 1. Re: Text disappears by online publishing used Publish Online, version 2015.4
          Steve Werner Adobe Community Professional & MVP
          You could have corruption in the InDesign document. Try saving as IDML (File > Save As > InDesign CS4 and later (IDML)).
          • 2. Re: Text disappears by online publishing used Publish Online, version 2015.4
            Hallo,
            thanks for response.
            I've tried saving the document as IDML, and my inDesign CC 2015.4 crashes always, approx ten times.
            I've tried earlier more than twenty new documents to publish using Publish Online, always with distext symptom,
            -mf-
            • 3. Re: Text disappears by online publishing used Publish Online, version 2015.4
              Hallo,
              I've reinstall the InDesign, and the IDML works -- but it doesn't help;
              the HTML code where the text visible (for example):
              <div id="_idContainer047" class="_idGenAnimation Basic-Text-Frame _idGenAnimationEnd-2" data-animationonpageloadactions="playAnimation(selfContainerID,'_idGenPlayAnimation-8',0, '');" data-idgenanimationstartstate="_idGenAnimationStart-2" data-idgenanimationendstate="_idGenAnimationEnd-2" data-idgenanimationclass="_idGenPlayAnimation-8">
                <img class="_idGenObjectAttribute-2" width="100%" height="100%" type="image/svg+xml" src="publication-web-resources/image/32.svgz">
                </div>
              the HTML code where the text non-visible (for example):
              <div id="_idContainer058" class="_idGenAnimation Basic-Text-Frame _idGenAnimationEnd-2" data-animationonpageloadactions="playAnimation(selfContainerID,'_idGenPlayAnimation-10',0 ,'');" data-idgenanimationstartstate="_idGenAnimationStart-2" data-idgenanimationendstate="_idGenAnimationEnd-2" data-idgenanimationclass="_idGenPlayAnimation-10">
                </div>
              that is if the text is non-visible, this is because InDesign doesn't generate the img (svg) element,
              -mf-
