4 Replies Latest reply on Sep 2, 2016 3:26 PM by Peru Bob
    What should I upgrade for better 4k performance?
    StuS21
      Hi All,
      I've started shooting with an A7Sii, and though I'm getting better 4k performance than I thought from my system, it's not quite there.  Specifically, my timelines tend to become a bit sluggish, and are developing stuttery playback over time at full resolution to my client monitor. I've also had one or two PPro crashes, which is rare for me, though this could just be a coincidence.  My timelines aren't that long or complex, though I generally grade and sharpen in PPro, but that's about it for effects. I don't feel that performance is that far off, and am wondering what upgrade folks think will get me the best performance upgrade.  In looking back at my build notes, I was amazed to find that this system is 4.5 years old, but I don't think I have to (and can't afford to), pull it apart and start over.  Here's the system basics:
      p9x79pro
      i3930 3.2 (overclocked by ADK to 4.5)
      32 gb of crucial ram
      evga gtx670 4gb superclocked
      corsair hx1050w
      Windows 7 pro
      Creative Suite CS6
      On playback, the CPU usage seems good on all 5 cores, peaking in the mid 30 to upper 40 % range while playing back graded clips  My first instinct is to think about a gtx 970, I'm wondering what people think, and if others have used it with the p9x79/3930 combo.
      Thoughts?
      Thanks!
      Stu
        • 1. Re: What should I upgrade for better 4k performance?
          RoninEdits Most Valuable Participant
          you may want to download GPU-Z and see what the usage is like (gpu load %). if you remove all of the gpu fx and get smooth playback, that might also suggest the gpu is holding things back. if you decide to upgrade the gpu, you should look at the new gtx 1060 6gb. its faster and has more memory.
          what kind of storage drives and setup do you have?
          • 2. Re: What should I upgrade for better 4k performance?
            StuS21 Level 1
            Thanks for the quick reply RoninEdits, it's very helpful.  Media is on an internal 2 TB RAID1, don't think that's it.  A quick test confirms that clips that stutter with multiple layers of color correction do not stutter with cc disabled.  I'll confirm with GPU-Z, but I think my suspicion is confirmed. Do you think the 1060 is compatible with my system?  I know the power supply is large enough.
            • 3. Re: What should I upgrade for better 4k performance?
              the pcie gen 3.0 video cards are suppose to be backwards compatible, but every once in a while an old motherboard and new gpu don't get along. sometimes a bios update on the motherboard can fix it, or a different brand gpu. you may want to search the web for your motherboard and any of the new gtx 1060/1070/1080 cards, to see if people are having problems. i searched for a few minutes and wasn't finding anything. i found some using the gtx 900 series, which is a good sign the gtx 1000 series might work. the i7-3930k cpu you have is only pcie gen 2.0, so it won't be able to run gen 3.0 speeds. that may slow down the gtx 1060 a little, but not enough to be concerned about.
              if you can borrow a new gtx 1000 series card from someone to test, it could also confirm the upgrade is needed and those cards will work with your motherboard. buying one from a store that has an easy/good return policy might also be good if there is a problem.
              • 4. Re: What should I upgrade for better 4k performance?
                Peru Bob Adobe Community Professional & MVP
                I'd give Eric at ADK a call.
