35 Replies Latest reply on May 3, 2017 3:53 AM by drloksoft Branched from an earlier discussion.
    Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
    DustinF00 Level 2
      I am experiencing MASSIVE lag and delays between image to image in the develop module - sometimes huge hangs and the screen goes BLACK and I have to wait 3-5 seconds.
      sometimes I see an APPLICATION show up in the task bar that states "BEZEL" and sometimes I see an application show up that states "SHADOW" but its a mess - really horrible performance.
      My entire system for Windows 10, LR Catalog (which is large, this happens on NEW small catalogs too), and RAW files are all on NVME PCIe drives. This also happens on the NVIDIA GTX780 card and then when that card died I thought it was that card that caused my issues but it happens on a brand new GTX1070 card that is now installed.
      I've turned ON and OFF HyperThreading with no effect, Turned ON and OFF the GPU accelleration to no effect.
      I've Turned ON and OFF the Windows Defender and other Virus/Spy/Malware detectors from MSFT - and those are the only ones installed on the system.
      Here is my machine details from System Info:
      Lightroom version: CC 2015.6.1 [ 1083169 ]
      License: Creative Cloud
      Operating system: Windows 10
      Version: 10.0
      Application architecture: x64
      System architecture: x64
      Logical processor count: 14
      Processor speed: 2.5 GHz
      Built-in memory: 65447.9 MB
      Real memory available to Lightroom: 65447.9 MB
      Real memory used by Lightroom: 722.1 MB (1.1%)
      Virtual memory used by Lightroom: 694.3 MB
      Memory cache size: 0.0 MB
      Maximum thread count used by Camera Raw: 14
      Camera Raw SIMD optimization: SSE2,AVX,AVX2
      System DPI setting: 96 DPI
      Desktop composition enabled: Yes
      Displays: 1) 2560x1600, 2) 1920x1200
      Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
      Graphics Processor Info:
      GeForce GTX 1070/PCIe/SSE2
      Check OpenGL support: Passed
      Vendor: NVIDIA Corporation
      Version: 3.3.0 NVIDIA 369.09
      Renderer: GeForce GTX 1070/PCIe/SSE2
      LanguageVersion: 3.30 NVIDIA via Cg compiler
      Application folder: C:\Program Files\Adobe\Adobe Lightroom
      Library Path: I:\DFP-LightroomCatalog\DustinFinnPhotography_Catalog\DustinFinnPhotography_Catalog.lrcat
      Settings Folder: C:\Users\dustin\AppData\Roaming\Adobe\Lightroom
      Installed Plugins:
      1) SmugMug
      Config.lua flags: None
      Adapter #1: Vendor : 10de
        Device : 1b81
        Subsystem : 85961043
        Revision : a1
        Video Memory : 8145
      Adapter #2: Vendor : 1414
        Device : 8c
        Subsystem : 0
        Revision : 0
        Video Memory : 0
      AudioDeviceIOBlockSize: 1024
      AudioDeviceName: Speakers (Realtek High Definition Audio)
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: LR5x102
      Direct2DEnabled: false
      GL_ACCUM_ALPHA_BITS: 16
      GL_ACCUM_BLUE_BITS: 16
      GL_ACCUM_GREEN_BITS: 16
      GL_ACCUM_RED_BITS: 16
      GL_ALPHA_BITS: 0
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_SIZE: 32768
      GL_MAX_TEXTURE_UNITS: 4
      GL_MAX_VIEWPORT_DIMS: 32768,32768
      GL_RED_BITS: 8
      GL_RENDERER: GeForce GTX 1070/PCIe/SSE2
      GL_SHADING_LANGUAGE_VERSION: 4.50 NVIDIA
      GL_STENCIL_BITS: 8
      GL_VENDOR: NVIDIA Corporation
      GL_VERSION: 4.5.0 NVIDIA 369.09
      GPUDeviceEnabled: false
      OGLEnabled: true
      GL_EXTENSIONS: GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_vertex_shader_viewport_index GL_AMD_vertex_shader_layer GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_locations GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_sparse_texture2 GL_ARB_sparse_texture_clamp GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_minmax GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_provoking_vertex GL_EXT_raster_multisample GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_sparse_texture2 GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KTX_buffer_region GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NVX_blend_equation_advanced_multi_draw_buffers GL_NV_blend_square GL_NV_clip_space_w_scaling GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_conservative_raster GL_NV_conservative_raster_dilate GL_NV_conservative_raster_pre_snap_triangles GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_fill_rectangle GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_coverage_to_color GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_fragment_shader_interlock GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_geometry_shader_passthrough GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_float64 GL_NV_shader_atomic_fp16_vector GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_stereo_view_rendering GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
        • 1. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
          28axmelissarios Adobe Employee
          Hey DustinF00,
          Can you share a screenshot of the icons in your system tray? Also, any videos that you have will be helpful for others in the forums. I also noticed that you don't have the latest driver for that graphics card. There have been two updates since yours with the latest released Aug. 30th.
          Do you have more information about your two monitors?
          Thanks.
          Melissa
          • 2. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
            DustinF00 Level 2
            Attached below are some computer details from Device Manager outlining the displays, the display adapter and CPU type.
            Here is a screen cap of the icon tray - it should be clear that the icon with the yellow exclamation mark is a portable scanner that is not conncected at the moment, this is windows 10 Second Edition, The Display adapters have since been upgraded, one drive is loaded but not signed into, Dropbox is loaded and signed into and doesnt sync any lightroom files or folders, BT is NOT in use and the first icon is a backup software that runs on scheduled times that I am not at the computer and only copys the RAW folder to another NAS device.
            I am working on getting the performance problems on video in a better way - it is clear to me that Lightroom does NOT grab the resources its being handed with this type of build computer (lots of speed on SSD, RAM, and CPU) and sometimes is glitched bad.
            My key complaints are image to image time delay/waiting for the images to be accessible in the edit panel and then on batch export Lightroom will flash to a black screen, sometimes show a new task in the task bar called "bezel" and sometimes called "shadow".
            Running windows performance monitor doesnt show anything else using resources or CPU to take away from lightroom, It's just lightroom waiting on something I cannot figure out what it is...
            • 3. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
              DustinF00 Level 2
              Here is the latest output of the System Info from the Help of LR - I even moved the LR Catalog around with no difference in large quantity image edits.
              I also turned off hyper-threading to just see if there as anything else that could be causing this. It did not change performance.
              Version: 10.0
              Real memory used by Lightroom: 2803.7 MB (4.2%)
              Virtual memory used by Lightroom: 3328.3 MB
              Version: 3.3.0 NVIDIA 372.70
              Library Path: F:\DFP-LightroomCatalog\DustinFinnPhotography_Catalog\DustinFinnPhotography_Catalog.lrcat
              Installed Plugins:
              1) SmugMug
                Device : 1b81
                Revision : a1
                Video Memory : 8145
                Device : 8c
                Subsystem : 0
                Revision : 0
                Video Memory : 0
              Build: LR5x102
              GL_ALPHA_BITS: 0
              GL_BLUE_BITS: 8
              GL_DEPTH_BITS: 24
              GL_GREEN_BITS: 8
              GL_RED_BITS: 8
              GL_STENCIL_BITS: 8
              GL_VERSION: 4.5.0 NVIDIA 372.70
              OGLEnabled: true
              GL_EXTENSIONS: GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_vertex_shader_viewport_index GL_AMD_vertex_shader_layer GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_locations GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_sparse_texture2 GL_ARB_sparse_texture_clamp GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_minmax GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_provoking_vertex GL_EXT_raster_multisample GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_sparse_texture2 GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NVX_blend_equation_advanced_multi_draw_buffers GL_NV_blend_square GL_NV_clip_space_w_scaling GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_conservative_raster GL_NV_conservative_raster_dilate GL_NV_conservative_raster_pre_snap_triangles GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_fill_rectangle GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_coverage_to_color GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_fragment_shader_interlock GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_geometry_shader_passthrough GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_float64 GL_NV_shader_atomic_fp16_vector GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_stereo_view_rendering GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
              • 4. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                ssprengel Adobe Community Professional & MVP
                From your description of the screen blacking out I'd guess it's a video driver/card problem.  You have a new card and the newest driver.
                it seems odd that disabling and enableing Use Graphics Processor in LR / Prefs / Performance wouldn't make any difference.  What I would expect is that while things might not work in either mode, the symptoms would be a little different.  If the system acts exactly the same then it seems that OpenGL is not being used at all, since that is what turning on and off Use Graphics Processor controls.
                Something to try would be vary the number of resolution of the monitors you have connected.  The first thing to try would be set the low-res monitor as the primary monitor then actually disconnect the high-res one and reboot and see if things are at least a little faster.
                Also watch the CPU usage when you flip to a new image with the GPU on and off, and see if more is used when the GPU is off, or not.
                Hopefully the previous Adobe employee would be able to get you a special copy of LR with some instrumentation turned on to log things--I don't know if such a version exists, but it'd be nice if it did and someone could have you run it for them to see where the bottle-neck is.
                • 5. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                  DustinF00 Level 2
                  I think from what I can decipher, this is a memory management thing - when using a large total of images in a develop module some how Lightroom takes up about 4-6GB of RAM - it doesnt know what to do with itself.
                  It also doesnt peg and pin any CPUs or GPUs during image to image transition (still laggy) and I know I have a rather large catalog but optimizing doesnt change most of this image to image lab and the large images in develop module still seem to drag it down.
                  I really would like the engineers that figured out how to code PRemier and Photoshop for multiple CPU and large RAM use would get assigned to fixing LR.
                  And finally - yeah - it would be great to get LR in a debug/logging mode and see where its deficiencies are...
                  • 7. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                    DustinF00 Level 2
                    Performance is still way out of whack though - I used to be able to break up my exports - if I had to export 650 RAWs to JPG - I would take them in 300 or so groups - and then export each group of images, setting up 3 parallel tasks - I cannot even get the second batch to start up without some massive lag... Lightroom is stuck on something - I dont know if its the 64GB or RAM it sees or the 14+ cores CPU or its not expecting the SSD disk speed I've given it access to
                    • 8. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                      Do you not have 64GB of RAM?  LR using up 8GB of RAM seems normal if you have a big catalog and exporting a bunch of photos.  In the portion of the video I'm looking at, you don't show the memory usage from before you started the Export, but the memory is going up and down somewhat during the few seconds you do show.  I'm also not seeing what the virtual-memory swap file size is, but maybe I missed it.
                      Not using 100% CPU just means that LR is getting slowed down by the disk-I/O (even though to an SSD).  I don't think LR uses the GPU during Export.  With spinning hard disks instead of SSDs, LR could run more things in parallel because of the disk latency but now the SSDs are fast enough getting it data that I think it's maxing out the I/O bus.
                      That shouldn't make the screen go black, though, and it's interesting it's only the LR portion that's black, not the entire screen because we can still see the task bar.
                      Did you upgrade Windows 10 from Windows 8.x or is this a fresh install?
                      2 people found this helpful
                      • 9. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                        DustinF00 Level 2
                        This is a fresh install of Windows 10 Second Edition and the disks where the RAWs are and the Catalog are all high-speed NVME PCIe SSDs - these are ridiculously fast.
                        The Machine does have 64GB of RAM.
                        These are the READ and WRITE speeds on the SSD's installed in this computer.
                        Here is a screen shot of the CPU Performance Monitor with Hyper-Threading enabled (it was disabled in the other video as I was testing different configurations in the BIOS to see what could help eliminate this Lightroom Lag/Performance problem)
                        • 10. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                          TiverDA Level 1
                          I have encountered similar problems with AMD cards, I have to reinstall win, sometimes it appears more than once, sometimes not. I think due to unstable power line, or the problem could come from your LCD display.
                          Check the LCD screen wire, check the PSU, cables to connect from the LCD Case, I do not think the problem is in the Video Card
                          • 11. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                            DustinF00 Level 2
                            Hi, Thank you for your reply but the LCD, cable or power supplies are not the cause at this time. The entire LCD does NOT go black, the video shows that Windows TaskBar is still visible - and only the Lightroom main application window goes black, the Lightroom Window Frame is still open and the Lightroom Windows Frame reads the Lightroom name.
                            I have been building computers for 20 years and this computer is the most power ful I ever built in the last 4 years - Adoble Premier, Photoshop all work properly and seem to know how to access and perform well with the speed and power available to it...
                            • 12. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                              simonsaith Adobe Employee
                              Try the following to see if it works better for you. The workaround will make Lightroom use less computing resource (disk i/o, RAM and CPU) when the export is running in the background. This will allow Lr to be more responsive during that time:
                              1. Open Lightroom.
                              2. Invoke Lightroom > Preferences... menu command
                              3. When the Preferences dialog appears, select the Presets tab.
                              4. Click on the button labeled “Show Lightroom Presets Folder...”
                              5. Lightroom will reveal the root preset folder in the Finder/Explorer.
                              6. Now goto http://adobe.ly/2aKPUhq and download the config.lua file and copy it into the root preset folder at step 5. The config.lua file will turn off the under-the-hood concurrent export sessions intended to speed up the export on high end machines (4 cores or higher).
                              7. Relaunch Lr and see if you can still reproduce the crash/hang on export.
                              8. Remove or rename the config.lua from the root preset folder after the experiment (to restore to the original Lr 6.6.1 behavior). If it works out for you, you can leave this workaround in place while we investigate the issue based on the crash dump.
                              • 13. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                DustinF00 Level 2
                                What if I store presets with the catalog?
                                • 14. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                  DustinF00 Level 2
                                  I tried placing the file in both places of my presets folder, the one with the stored catalog and the one in the windws/users/appdata folder.
                                  I saw no different in performance, I saw all 14 cores rise with use on an export and I continue to see Lightroom go into " (not responding) at the top title bar if I decide to try to scroll through the files in the roll while its performing an export.
                                  • 15. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                    DClark92064 Level 1
                                    I was having similar performance issues on a system similar to yours.  Seemed to start after a CC update. I finally went into Adobe CC and uninstalled LR then reinstalled it.  Problems cleared up.  Don't know why.  If you haven't done this give it a try.
                                    • 16. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                      Storing the presets in the catalog does not affect the placement of the config.lua file. After putting the config.lua in place, goto the Lightroom>System Info...  You should see it includes an entry like the follows:
                                      Config.lua flags:
                                      disableAdaptiveConcurrentSessions = true
                                      • 17. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                        Do you always experience the performance problem when there is one or more export sessions running in the background? It seems to be the case shown in the video. If there is no concurrent export tasks in the background, is the performance ok?
                                        • 18. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                          DustinF00 Level 2
                                          I experience performance issues even when an export is not happening. without an export running, I still an image to image selection delay of many seconds before the editor applet can be used and then when the editor applet is finally available I can grab sliders and drag them and they do not drag with the mouse but drag afterwards, in fact I can drag a bunch of different sliders in all different directions and none of them actually equal to my mouse moving when I drag them and then they will all move afterwards...
                                          Maybe we need to set my expectations, although I never really remember this issue EVER before - maybe I can't scroll through images while a background export is happening ?
                                          Maybe Lightroom isnt meant to have 1000 RAW files loaded into for my wedding work and edit 600 of them?
                                          Maybe I have to treat it like when I used to burn CD ROM Disks in 1999 and leave the entire Lightroom App alone and not do anything until its done.
                                          It's not clear to me where this issue - I am fully open to signing NDA and testing software releases or debug applications - my Full Time Day Job has a significant level of hardware and software testing involving platforms...
                                          I will run the test again and look to make sure the settings have taken effect. I also hope to find the time take video to continue to troubleshoot this issue - its really a painful experience to use this software now.
                                          • 19. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                            2drumstix Level 1
                                            I have just about the same issues as you DustinF00. In MHO, LR has just become a pretty unusable piece of software, sad really because it "was" really great. I shoot for a living, and most often don't have time to research "workarounds", which has become the new standard for Adobe products. I actually have work to do, not time to sit around f-ing with my computer to make some software work correctly. And even if I did have time to F-around, I would rather do something else than chase workarounds and fixes. I never update CC until just about when the next version is getting released, because I have work to do and cant afford to cause my self hours of tracking down BS from an update. Yes, this is a rant, sort of. Fact is, LR performance issues exist. Perhaps they should dump all the loaded crap like Map and Book, and face recognition, and buttons for facebook and flicker and all those other useless things, and get back to making a photo management and editing software, like it was before LR5, just a thought. I almost got out my LR1 DVD and loaded it the other day because I have work to do.
                                            I have a pretty fast PC, M.2's, SSDs, 64gmem, i7 8 core, 2 internal RAIDS of about 12TB each, water cooled, big fans, GTX980, all the good ****. I can edit in Premiere with 6 mulitcam angles, with multiple audio tracks, from different sources, with all sorts of effects, titles, slides, and so on.. But, I can only work in LR for about 25-35 mins before it starts to slow to basically a crawl, restart and start again. I've always been of the belief that software should just work, especially if you have a less than 2 year old machine. And that I shouldn't really have to do anything but install it, set it up, and use it.
                                            • 20. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                              DustinF00 Level 2
                                              Just finished this unisntall and re-install - what a mess - that didnt fix anything - still laggy performance.
                                              • 21. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                DustinF00 Level 2
                                                Yes, I cannot say I disagree with you 2drumstix - it appears to lag really fast and we have similar setups with lots of RAM and fast SSDs - it really seems LR cannot handle the threading its been provided and must be choking some where.
                                                And yeah - I am not that great at premier, but I am having no issues there, and that application sucks up as much power as it wants from the CPUs (14 cores, even 28 hyperthreaded) - so there it knows how to handle this.
                                                I even have a more powerful GPU now - there has GOT to be a way to manage this GPU power, massive cores on CPUs and the RAM and SSD speeds...
                                                • 22. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                  sebastianb28672093 Level 1
                                                  I too have some new performance issues like yours... I just discovered it today after I have installed "Nvidia GeForce Experience V3.0.5.22" or maybe after I updated the video drivers of my GTX980 to V372.70...
                                                  • 23. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                    DustinF00 Level 2
                                                    I uninstalled the NVidia graphics experience thing a few days ago - still slow lag in Lightroom...
                                                    We're going to learn somewhere two things:
                                                    1. MSFT changed the way its handling file I/O with its new defender/sercurity apps
                                                    2. Adobe let all the Lightroom engineers that could have made this is a better application work on something else and we now have the B-Team working on Lightroom in a sustaining role and not an innovation role to take advantage of the MultiCore/Multi-Threaded Lanes of data LR can now have...
                                                    We need Adobe and Microsoft and more to get together for issues like this...
                                                    • 24. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                      DustinF00 Level 2
                                                      Following up on this - I noticed with this config, the machine locks and holds at 1% rendering 1:1 previews - it seems to just sit there for ever - I took the config out and it can work back to the regularly garbage performance...
                                                      Has Adobe Lightroom set up a whole set of outlines for best performance blog post or spec sheet in support? I see a lot of bloggers like to say they know how to make lightroom work faster - but some or most of that seems to be about click and search stuff and less about actually wokring and knowing what to do.
                                                      • 25. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                        The email notification for this forum does not work for me. So I need to remember to check back this thread for info. Sorry for the delay in response.
                                                        The config should have nothing to do with the 1:1 preview generation. It only affects the export if it is running. More questions:
                                                        1. Do you always running a dual monitor setup when you experience the problem? What happens if you only use the primary monitor.
                                                        2. So far your main issue is the multiple seconds delay when walking image from one to another, especially when you jump to the new image non-sequentially.
                                                        3. You also experience image rendering does not keep up with the slider change? Which setting is that?
                                                        4. Can tell if you have anything else that differs your setup from others? Like do you use any 3rd party plug-ins? Lots of presets?
                                                        • 26. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                          DustinF00 Level 2
                                                          1.
                                                          I have always run dual monitors with this computer setup, I didnt start seeing these issues until moving into the further releases of Adobe Lightroom.
                                                          2a.
                                                          My main concern is Lightroom overall performance degredation in the last few releases, however I cannot pin it all on Adobe because I've also had the MSFT Anniversary update happen which doesnt seem to be the trigger for the slowness after the 72 hours of installing the original release of windows 10.
                                                          2b. A list of issues at the moment are as follows;
                                                          * Image to Image switching takes seconds for the control panels to become usable, then once they go from grayed out to highlighted there is a delay in dragging sliders.
                                                          * Image Export to JPG  renders the Lightroom application USELESS, it is 100% locked up exporting images, I used to batch multiple groups - now I cannot even select another group to batch export. Further issues during export is that the ADOBE LIGHTROOM Windows goes black -NOT WINDOWS, NOT THE SCREEN, just Adobe Lightroom, sometimes I even see (Not Responding) in the title bar window - which means the OS cannot even talk to the Adobe Lightroom application, during this lock up/freeze super slowness I sometimes see the Windows Task Bar show an additional application listed, sometimes its "SHADOW" and sometimes is "BEZEL" none of which I can capture on video yet.
                                                          3. I am not sure what you mean by rendering, I notice the sliders don't keep up with the cursor and they move after I've click/dragged the slider and move the mouise away - this can happen on everytthing from exposure, black point, highlights, clarity white balance, its on all of the sliders.
                                                          4. Only pluig-ins I am using right now is the SmugMug plug-ing, the Presets are VSCO, thats left panel work though and they load fast without issues, its everything in the develop module that seems tank on me.
                                                          • 27. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                            Follow up questions:
                                                            1. If you use a single primary monitor setup, does it improve things for you. The reason that I ask is that we heard some reports it might affect some customers when the GPU is turned on.
                                                            2b. If you are used to mange the multiple batch exports at the same time yourself, then leave the config.lua that I provided in place. The latest version of Lightroom by default tries to maximize the efficiency of a single export by doing multiple simultaneous exports under-the-hood for you automatically. The config.lua would turn that off to give you back the manual controls.
                                                            4. Can you try to do with and without the VSCO presets (by moving them to the desktop and then moving back) and see if it makes a difference. Some VSCO presets are camera model specific so it could affect the walking speed. How many total number of VSCO presets that you have installed?
                                                            • 28. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
                                                              DustinF00 Level 2
                                                              I have to test the disconnecting of a second monitor.
                                                              I can change my workflow to massive single batch exports - but I gotta say this is still insane to me because of the power the computer has - Lightroom just take the power it has available - even with a single group of edits the performance is clearly not using the bandwidth in the computer.
                                                              I seem to see no difference walking in the develop module with or without the presets in the folders and loaded - I only have the standard  presets installed, non-camera specific ones, but they arent applied.
                                                              Can you provide some insight into what the Lightroom applicaiton is doing between image to image? there is a massive delay and its clearly waiting to read a file. ALL drives in the computer are NVME - none of them have a read speed lower than 1Gbit.
                                                              Is there a start up switch, a log enabled version, I am willing to test to the extreme, willing to take on beta versions and willing to take on NDA so I dont talk about what we do publicly or privately. This is just totally horrific - I cannot work this way at all...
                                                              • 29. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
        DustinF00 Level 2
        Maybe I can ask the question in a different way:
        Should I expect to be able to - count seconds like 1-Mississippi 2-Mississippi 3-Mississippi all the way to 5 sometimes 8 and 10 before I get to edit an image (have access to sliders and use them?).
        Right now just Using 24MP JPGs from a camera I have this lag.
        • 30. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
        Jao vdL Adobe Community Professional & MVP
        No that is way too slow on that monster of a machine you have there. My main machine is a several year old laptop with an i7 (4 cores) that is much faster than this with raw files from a 24 MP camera. There seems to be something about really high power machines with large number of cores that Lightroom just can't deal with very well for some reason.
        • 31. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
        DustinF00 Level 2
        Thats the next step - is to drop the bios active cores to something like 4 and see what happens...
        I created an entirely new catalog and dropped JPGs into it and its massively slow...
        • 32. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
        trshaner Adobe Community Professional & MVP
        What processor are you using in your system? This doesn't look right:
        I'm not aware of any processor that has 7 cores (i.e. 14 with Hyperthreading).
        Try the suggestions at the below post and add your comments and a link to this post in your reply:
        Lightroom: Clone and brush tool are slow only on CPU with XEON architectures | Photoshop Family Customer Community
        • 33. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
        DustinF00 Level 2
        I will look into the Xeon thread, this is a Xeon processor wth 14 cores and hyperthreading turned off - i have sknce enabled and now have 28 threads.
        All useless to lightroom Apparently.
        • 34. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
        pashac92050670 Level 1
        The problem may be an antivirus software. Exclude lightroom.exe from Window Defender or any other AV you may have.
        • 35. Re: Lightroom CC / 2015.6.1 hangs and freezes on Windows 10
        drloksoft Level 1
        Thanks for the suggestion. It does not make a difference, even if I turn Defender off completely.
