4 Replies Latest reply on Sep 2, 2016 3:59 PM by Obi-wan Kenobi
    Problem of geometric bounds! …
    Obi-wan Kenobi Level 5
      Hi all,
      My Doc has the same page format with a similar text frame on each page and it has several pages!
      I have a loop on the results of a grep find/replace.
      With this:
      for (i = 0; i < myFound.length; i++)
             var myFrame = myFound[i].parentTextFrames[0];
             var myBaseline = myFrame.geometricBounds[2] - myFound[i].baseline;
      I would like to calculate myBaseline, but I get an error on line 04.
      In fact, what I want to get the position of text by reference at the bottom of its text frame!
      Thanks in advance!
      (^/)  [tired tonight!]
        • 1. Re: Problem of geometric bounds! …
          Skemicle Level 3
          I set myFound to app.selection and this gives the distance from the baseline of the selection to the bottom of the text frame. So I'm thinking that if you insert app.selection = myFound[i] before your myBaseline variable and change myFound[i].baseline; to app.selection.baseline It may work.. but i haven't really done anything with grep find/replace in scripts so i don't know how to go about testing my theory... (yet) =P
          • 2. Re: Problem of geometric bounds! …
            Hi Skemicle!
            The selection is OK with this! … But apparently the problem seems to be on the line 03.
            Not really sure this line works!
            • 3. Re: Problem of geometric bounds! …
              Loic.Aigon Adobe Community Professional
              Hi Michel,
              Great chances here that the text object is actually hidden. In this case, parentTextFrames length equals 0 and accessing a property of a non valid reference would throw your error.
              You may want to first check if the reference is valid through
              if ( myFound[i].parentTextFrames[0].isValid ) {
                   //do whatever you need
                  else {
                   //do something different.
              Loic
              http://www.ozalto.com/
              • 4. Re: Problem of geometric bounds! …
                Hi Loïc,
                The text object wasn't hidden, but you're totally right when you said that something was not "valid"!
                The word put me on the right track!
                The script works before I modify this point:
                Before: the script compared the "baseline" to a delimiter X
                After: it compares "bottom of the text frame - baseline" to a new delimiter Y
                What I forgot to change, below the code lines I showed, is the direction of the sign:
                if (myBaseline > myDelimiter) {
                … to:
                if (myBaseline < myDelimiter) {
                "Noodle you are, young padawan!
                to sleep, you have to go!"
                often said to me my Master Yoda!
                Thanks!
                MTFBWY!
