0 Replies Latest reply on May 3, 2006 3:05 PM by >Vee<
    works only once
    >Vee< Level 1
      Below I have my code which takes two input text fields and puts the sum into the total. The problem I'm having is the way the code is below the submit_btn only works the equation once. If I change the values Im entering in the a1_txt or a2_txt then hit submit_btn again, nothing happens; it keeps the prior total. If you use the commented statement all works fine - why is this?
      Side question: is there a way to hold or save the users values they enter in a1_txt or a2_txt into an XML file? then reload them when they log back in?
