3 Replies Latest reply on Jan 3, 2009 9:25 AM by kglad
    Please help me understand AsBroadcaster
    combustion007 Level 1
      Hello,
      I would highly appreciate it if someone can help me understand the functionality behind asBroadcaster. I have been trying to understand this example at:
      http://www.kirupa.com/developer/actionscript/asbroadcaster2.htm
      But it hardly serves the practicality for me. Can I use a AsBroadcaster for such purpose as:
      Lets say if I had a movie clip "btn" on the stage, and there are four more movie clips on stage as well. Can I make the four movie clips as listeners? And the "btn" as the broadcaster, so when I press the "btn" clip, I can fire a function that would bring "_alpha" down to 50 for all the listener clips?
      Thank you.
        • 1. Re: Please help me understand AsBroadcaster
          there's no reason to use the asbroadcaster for events that are already broadcast. specifically, mouse events (like onPress) are already broadcast by buttons and movieclips:
          btn.onPress=function(){
          mc1._alpha = 50;
          mc2._alpha = 50;
          // etc
          • 2. Re: Please help me understand AsBroadcaster
            Hello kglad,
            Thank you for that. The reason, I am exploring AsBroadcaster, because I would like to move things around when one particular movie is loaded. So if this movie gets loaded, all the other movies shift their_x, and _y and this only happens when one particular movie is loaded.
            I thought about making and function and then passing an array of the movies as argument. This function will only be executed when this particular movie clip is loaded.
            Am I on right path?
            Thanks a lot.
            • 3. Re: Please help me understand AsBroadcaster
              probably not.
              you would use the asbroadcaster for an event that flash doesn't detect with its standard listeners. flash already has an onLoadComplete() method for the moviecliploader class - but you'll probably want to use onLoadInit().
              it makes no more sense to create a custom onloadcomplete listener than it would to make a custom movieclip class that does nothing different than the standard flash movieclip class.
