1 Reply Latest reply on Sep 5, 2016 5:49 AM by Bernd Alheit
    C# - Certifikované časové razítko do PDF
    Flexam
      Ahoj všem,
      potřeboval bych poradit s vložením certifikovaného časového razítka do PDF.
      Níže uvedený zdrojový kód, který spadne na řádku Array.Copy(pk, 0, outc, 0, pk.Length); protože outc.Length = 4096, ale pk.Length = 7541. Metoda DejCasoveRazitko funguje bez chyby.
              private const String ID_TIME_STAMP_TOKEN = "1.2.840.113549.1.9.16.2.14"; // RFC 3161 id-aa-timeStampToken
              public void PodepisPdfCer(string SouborPDF, string OtiskCertifikatu)
                  //http://www.dotnetportal.cz/blogy/15/Null-Reference-Exception/5250/Digitalni-podepisovani-P DF-souboru-v-C-cast-2
                  //Get certificate
                  //Open the currently logged-in user certificate store
                  var store = new System.Security.Cryptography.X509Certificates.X509Store(System.Security.Cryptography.X509 Certificates.StoreName.My, System.Security.Cryptography.X509Certificates.StoreLocation.CurrentUser);
                  store.Open(System.Security.Cryptography.X509Certificates.OpenFlags.ReadOnly);
                  string thumbprint = OtiskCertifikatu.Replace(" ", "").ToUpperInvariant();
                  if (thumbprint[0] == 8206)
                      thumbprint = thumbprint.Substring(1);
                  //Select a certificate from the certificate store
                  var certs = store.Certificates.Find(System.Security.Cryptography.X509Certificates.X509FindType.FindBy Thumbprint, thumbprint, true);
                  store.Close();
                  //Verify that a certificate exists
                  if (certs.Count == 0)
                      MessageBox.Show("Nelze najít určený certifikát v Current user certificate store!", "Sign PDF", MessageBoxButtons.OK, MessageBoxIcon.Warning);
                      return;
                  //Open Pdf document
                  byte[] pdfData = File.ReadAllBytes(SouborPDF);
                  //Sign the PDF document
                  using (MemoryStream stream = new MemoryStream())
                      var reader = new PdfReader(pdfData);
                      var stp = PdfStamper.CreateSignature(reader, stream, '\0');
                      var sap = stp.SignatureAppearance;
                      //Protect certain features of the document
                      stp.SetEncryption(null,
                          Guid.NewGuid().ToByteArray(), //random password
                          PdfWriter.ALLOW_PRINTING | PdfWriter.ALLOW_COPY | PdfWriter.ALLOW_SCREENREADERS,
                          PdfWriter.ENCRYPTION_AES_256);
                      //Get certificate chain
                      var cp = new Org.BouncyCastle.X509.X509CertificateParser();
                      var certChain = new Org.BouncyCastle.X509.X509Certificate[] { cp.ReadCertificate(certs[0].RawData) };
                      sap.SetCrypto(null, certChain, null, PdfSignatureAppearance.WINCER_SIGNED);
                      //Set signature appearance
                      BaseFont helvetica = BaseFont.CreateFont(BaseFont.HELVETICA, BaseFont.CP1250, BaseFont.EMBEDDED);
                      iTextSharp.text.Font font = new iTextSharp.text.Font(helvetica, 12, iTextSharp.text.Font.NORMAL);
                      sap.Layer2Font = font;
                      //sap.SetVisibleSignature(new iTextSharp.text.Rectangle(415, 100, 585, 40), 1, null);
                      var dic = new PdfSignature(PdfName.ADOBE_PPKMS, PdfName.ADBE_PKCS7_SHA1);
                      //Set some stuff in the signature dictionary.
                      dic.Date = new PdfDate(sap.SignDate);
                      dic.Name = certs[0].Subject;    //Certificate name
                      if (sap.Reason != null)
                          dic.Reason = sap.Reason;
                      if (sap.Location != null)
                          dic.Location = sap.Location;
                      //Set the crypto dictionary
                      sap.CryptoDictionary = dic;
                      //Set the size of the certificates and signature.
                      int csize = 4096; //Size of the signature - 4K
                      //Reserve some space for certs and signatures
                      var reservedSpace = new Dictionary<PdfName, int>();
                      reservedSpace[PdfName.CONTENTS] = csize * 2 + 2; //*2 because binary data is stored as hex strings. +2 for end of field
                      sap.PreClose(reservedSpace);    //Actually reserve it
                      //Build the signature
                      System.Security.Cryptography.HashAlgorithm sha = new System.Security.Cryptography.SHA256CryptoServiceProvider();
                      var sapStream = sap.GetRangeStream();
                      int read = 0;
                      byte[] buff = new byte[8192];
                      while ((read = sapStream.Read(buff, 0, 8192)) > 0)
                          sha.TransformBlock(buff, 0, read, buff, 0);
                      sha.TransformFinalBlock(buff, 0, 0);
                      //Place message in a ContentInfo object. This is required to build a SignedCms object.
                      System.Security.Cryptography.Pkcs.ContentInfo contentInfo = new System.Security.Cryptography.Pkcs.ContentInfo(sha.Hash);
                      //Instantiate SignedCms object with the ContentInfo above.
                      //Has default SubjectIdentifierType IssuerAndSerialNumber.
                      System.Security.Cryptography.Pkcs.SignedCms signedCms = new System.Security.Cryptography.Pkcs.SignedCms(contentInfo, false);
                      //Formulate a CmsSigner object for the signer.
                      System.Security.Cryptography.Pkcs.CmsSigner cmsSigner = new System.Security.Cryptography.Pkcs.CmsSigner(certs[0]);  //First cert in the chain is the signer cert
                      //Do the whole certificate chain. This way intermediate certificates get sent across as well.
                      cmsSigner.IncludeOption = System.Security.Cryptography.X509Certificates.X509IncludeOption.ExcludeRoot;
                      //Časové razítko z TSA
                      if (!String.IsNullOrEmpty(textBox_ServerCasovehoRazitka.Text.Trim()))
                          try
                              System.Security.Cryptography.AsnEncodedData timeData = new System.Security.Cryptography.Pkcs.Pkcs9AttributeObject(ID_TIME_STAMP_TOKEN,
        DejCasoveRazitko(stream.GetBuffer(), textBox_ServerCasovehoRazitka.Text)
                              cmsSigner.UnsignedAttributes.Add(timeData);
                          catch (Exception e)
                              MessageBox.Show("Chyba TSA!\n" + e.Message);
                      //Sign the CMS/PKCS #7 message. The second argument is needed to ask for the pin.
                      signedCms.ComputeSignature(cmsSigner, false);
                      //Encode the CMS/PKCS #7 message.
                      byte[] pk = signedCms.Encode();
                      //Put the certs and signature into the reserved buffer
                      byte[] outc = new byte[csize];
                      //Put the reserved buffer into the reserved space
                      PdfDictionary certificateDictionary = new PdfDictionary();
                      //certificateDictionary.Put(PdfName.CONTENTS, new PdfString(outc).SetHexWriting(true));
                      //Write the signature
                      sap.Close(certificateDictionary);
                      //Close the stamper and save it
                      stp.Close();
                      reader.Close();
                      byte[] signedData = stream.GetBuffer();
                      File.WriteAllBytes(SouborPDF, signedData);
              static protected byte[] DejCasoveRazitko(byte[] PDF, string ServerTSA)
                  System.Security.Cryptography.SHA256Managed hashString = new System.Security.Cryptography.SHA256Managed();
                  string hex = "";
                  var hashValue = hashString.ComputeHash(PDF);
                  foreach (byte x in hashValue)
                      hex += String.Format("{0:x2}", x);
                  // VSTUPEM je hash dokumentu, pro který se razítko vyžaduje
                  NotservisTSA.GetTimeStampRequest Request = new NotservisTSA.GetTimeStampRequest(new NotservisTSA.GetTimeStampRequestBody(hex, 0));
                  NotservisTSA.Print2PDF_WebServiceSoap Soap = new NotservisTSA.Print2PDF_WebServiceSoapClient();
                  ((NotservisTSA.Print2PDF_WebServiceSoapClient)Soap).Endpoint.Address = new System.ServiceModel.EndpointAddress(new Uri(ServerTSA + "/Default.asmx"));
                  PodepsaniPDF.NotservisTSA.GetTimeStampResponse Response = Soap.GetTimeStamp(Request);
                  // VÝSTUPEM je zakódované časové razítko (GetTimeStampResult - BASE-64 v kódované struktuře TimeStampResp, viz RFC 3161) a návratová hodnota s případným popisem chyby.
                  byte[] responseBytes = Encoding.ASCII.GetBytes(Response.Body.GetTimeStampResult);
                  if(!String.IsNullOrEmpty(Response.Body.Error))
                      MessageBox.Show(Response.Body.Error, "Chyba", MessageBoxButtons.OK, MessageBoxIcon.Error);
                  string base64String = Encoding.UTF8.GetString(responseBytes, 0, responseBytes.Length);
                  return Convert.FromBase64String(base64String);
