4 Replies Latest reply on Sep 6, 2016 6:00 AM by pedzsan
    temporal interpolation setting of "hold"
    pedzsan Level 1
      I'm viewing a tutorial on AE where he animates an object from A to B, sits at B for a while, then moves to C, sits a C for a while, then move to D, etc.  He puts a key frame when he gets to B and also when he leaves B and go to C.  Again, at C, he puts a second set of key frames.  So, the sequence of key frames is at positions A, B, B, C, C, D, D, E, E, ...
      So far... I get it.  But then he goes back and on the key frame where he arrives at B, he adds "Hold" -- changes the temporal interpolation setting to "hold".  I sorta understand why but what is odd to me is if I look at the graph editor, the position between the two "B" key frames at the same position is already absolutely flat.  So the "hold", in this case, isn't making any difference.
      I played around trying to get the interpolation between two key frames at the same position to not be flat and so far, I've not been able to.  Perhaps this tutorial is not a good example of when to use "Hold"?
      I understand that if you want the object to jump from A to B then you would use "Hold".
      Is using "Hold" in the above situation perhaps a throw back to earlier versions of AF and now AF automatically knows to keep the line between two key frames at the same value flat?
      Or is it perhaps the case that under weird circumstances, the value is not always a constant and so adding the hold is more a "just in case" type habit?
        • 1. Re: temporal interpolation setting of "hold"
          Roei Tzoref Adobe Community Professional
          it would help if we could see the tutorial, but what you are describing seems that Hold is not necessary.
          you use hold if you want no interpolation between 2 keyframes. if they are the same this means already there is no interpolation so it's not needed.
          Yes, Hold is for making the layer jump between keyframes
          No. this was always this way in Ae.
          • 2. Re: temporal interpolation setting of "hold"
            Gutterfish Adobe Community Professional
            Sometimes, i think because of my workflow, I get what i think is called "positional floating" on a keyframe.   It will be a situation like you say:  where an asset goes from a to b then spends some time there,  then when I'm ready for it to move on from b I set another keyframe where it's meant to start moving again.   Occasionally,  during that wait period between the two identical keyframes the asset will float away from it's position and then return before it moves.  These are the instances where I use a hold.  WHen this happens I can see it on the motion path in the viewport like a little loop and I could go in and fix it using the vertex handles but it's just quicker to use a hold.   Just another situation where someone might use a hold...it's not always a temporal issue.
            2 people found this helpful
            • 4. Re: temporal interpolation setting of "hold"
              pedzsan Level 1
              Ahh.... I had bumped into a link to the boomerang effect but I didn't click it.  I thought they were trying to create a boomerang effect.
              But... now I have another question.  Who was the voice on the first video?  That said, any video that starts out "Go day mate" is a must see
              Thank you for all your help.
