2 Replies Latest reply on Sep 6, 2016 4:50 AM by Vamitul
    Socket - xml back to server
      I have a long script running (on InDesign) that I would like to keep track of running on another PC in our network.
      I've created a simple Jquery/Boostrap web interface that reads in a XML file every few minutes. So what I am looking doing is have this long running script create a XML file, which the web interface will display.
      The issue I am having is constructing the XML to post back to the server. I can read a file fine.
      var website = "mySillytest.com:80";
      var path = "/thingy/newXMLDocument.xml";
      reply = "";
      conn = new Socket;
      if (conn.open (website)) {
          conn.write ("GET "+path+" HTTP/1.0\n\n");
          reply = conn.read(999999);
          $.writeln ("NO CONNECTION");
      I'm just overwriting the same file newXMLDocument.xml all the time at the same location this one is been read from.
      I have to use "POST" in conn.write, but I'm unsure how to proceed from there.
      Any pointers would be welcome.
        • 1. Re: Socket - xml back to server
          Loic.Aigon Adobe Community Professional
          If it's on a same network why not simply write the file to a shared volume ?
          var log = function(data) {
            var f = File ( "/shared/volume/directory/log.xml" );
            f.encoding = "UTF-8";
            f.writeln ( data.toXMLString() );
          var data = <data date="xxx" message="sdkljlqdjslk"/>
          log ( data );
          Ozalto | Productivity Oriented - Loïc Aigon
          • 2. Re: Socket - xml back to server
            Vamitul Level 4
            the .write() method's parameter is a string. So you can either construct the xml in memory and pass it to the write method (conn.write(theXml.toXMLString()) or,if you have the xml in a file, you need to open that file, read it's contents (close it) and pass the content to the connection.
            However, Loic is right. If you can use a file, don't bother with the socket.
            Or, if you want to use the socket, then your web app should not try to look for a file, but just accept incoming connections from indesign.
