3 Replies Latest reply on Sep 7, 2016 2:47 PM by georgew76584710
    Android build fail task :transformClassesWithDexForRelease
    georgew76584710
      Hi
      The Android build of my app has started failing recently (at least for the last 3 weeks, possibly prior).
      It seems if I remove the plugin cordova-plugin-analytics-adid then there is no error.
      iOS is building either way.
      I was building with phonegap cli-5.2.0, but now it fails with both cli-5.2.0 and cli-6.3.0.
      I tried an older version of the plugin cordova-plugin-analytics-adid, version 1.1.1 and 1.1.2 both fail.
      The error the log shows:
      * What went wrong:
      Execution failed for task ':transformClassesWithDexForRelease'.
      > com.android.build.api.transform.TransformException: com.android.ide.common.process.ProcessException: java.util.concurrent.ExecutionException: com.android.dex.DexIndexOverflowException: method ID not in [0, 0xffff]: 65536
      Any ideas about the cause of this issue, or possible fixes? Or alternatives to that plugin that still allows me to collect the google advertising ID?
      This issue looks related, however it doesn't really explain how I can fix the issue.
      Thank you!
      My App ID is 1543004
      Below are my config and build log
      <widget id="--- snip ---" version="1.5.2" xmlns="http://www.w3.org/ns/widgets" xmlns:gap="http://phonegap.com/ns/1.0">
          --- snip name, description, author ---
          <content src="index.html" />
          <preference name="phonegap-version" value="cli-6.3.0" />
          <preference name="BackupWebStorage" value="local" />
          <preference name="iosPersistentFileLocation" value="Library" />
          <preference name="DisallowOverscroll" value="true" />
          <preference name="BackupWebStorage" value="none" />
          <preference name="show-splash-screen-spinner" value="true" />
          <preference name="auto-hide-splash-screen" value="true" />
          <preference name="permissions" value="none" />
          <preference name="android-minSdkVersion" value="14" />
          <preference name="android-build-tool" value="gradle" />
          <gap:plugin name="cordova-plugin-file" version="~4.2.0" source="npm" />
          <gap:plugin name="cordova-plugin-file-transfer" version="~1.5.1" source="npm" />
          <gap:plugin name="cordova-plugin-geolocation" version="~2.2.0" source="npm" />
          <gap:plugin name="cordova-plugin-console" version="~1.0.3" source="npm" />
          <gap:plugin name="cordova-plugin-zip" version="~3.1.0" source="npm" />
          <gap:plugin name="cordova-plugin-inappbrowser" version="~1.4.0" source="npm" />
          <gap:plugin name="cordova-plugin-whitelist" version="~1.2.2" source="npm" />
          <gap:plugin name="cordova-plugin-transport-security" version="~0.1.2" source="npm" />
          <gap:plugin name="cordova-plugin-analytics" version="~1.4.0" source="npm" />
          <gap:plugin name="cordova-plugin-analytics-adid" version="~1.1.2" source="npm" />
          <allow-intent href="http://*/*" />
          <allow-intent href="https://*/*" />
          <allow-intent href="sms:*" />
          <allow-intent href="tel:*" />
          <allow-intent href="geo:*" />
          <access origin="*" />
          --- snip icons ---
      </widget>
      Android build log:
      Build Date: 2016-09-06 11:46:23 +0000
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAppcompatV72300Library
      :prepareComAndroidSupportMediarouterV72300Library
      :prepareComAndroidSupportSupportV42300Library
      :prepareComGoogleAndroidGmsPlayServices940Library
      :prepareComGoogleAndroidGmsPlayServicesAds940Library
      :prepareComGoogleAndroidGmsPlayServicesAdsLite940Library
      :prepareComGoogleAndroidGmsPlayServicesAnalytics940Library
      :prepareComGoogleAndroidGmsPlayServicesAnalyticsImpl940Library
      :prepareComGoogleAndroidGmsPlayServicesAppindexing940Library
      :prepareComGoogleAndroidGmsPlayServicesAppinvite940Library
      :prepareComGoogleAndroidGmsPlayServicesAuth940Library
      :prepareComGoogleAndroidGmsPlayServicesAuthBase940Library
      :prepareComGoogleAndroidGmsPlayServicesBase940Library
      :prepareComGoogleAndroidGmsPlayServicesBasement940Library
      :prepareComGoogleAndroidGmsPlayServicesCast940Library
      :prepareComGoogleAndroidGmsPlayServicesCastFramework940Library
      :prepareComGoogleAndroidGmsPlayServicesClearcut940Library
      :prepareComGoogleAndroidGmsPlayServicesContextmanager940Library
      :prepareComGoogleAndroidGmsPlayServicesDrive940Library
      :prepareComGoogleAndroidGmsPlayServicesFitness940Library
      :prepareComGoogleAndroidGmsPlayServicesGames940Library
      :prepareComGoogleAndroidGmsPlayServicesGass940Library
      :prepareComGoogleAndroidGmsPlayServicesGcm940Library
      :prepareComGoogleAndroidGmsPlayServicesIdentity940Library
      :prepareComGoogleAndroidGmsPlayServicesIid940Library
      :prepareComGoogleAndroidGmsPlayServicesLocation940Library
      :prepareComGoogleAndroidGmsPlayServicesMaps940Library
      :prepareComGoogleAndroidGmsPlayServicesNearby940Library
      :prepareComGoogleAndroidGmsPlayServicesPanorama940Library
      :prepareComGoogleAndroidGmsPlayServicesPlaces940Library
      :prepareComGoogleAndroidGmsPlayServicesPlus940Library
      :prepareComGoogleAndroidGmsPlayServicesSafetynet940Library
      :prepareComGoogleAndroidGmsPlayServicesTagmanager940Library
      :prepareComGoogleAndroidGmsPlayServicesTagmanagerApi940Library
      :prepareComGoogleAndroidGmsPlayServicesTasks940Library
      :prepareComGoogleAndroidGmsPlayServicesVision940Library
      :prepareComGoogleAndroidGmsPlayServicesWallet940Library
      :prepareComGoogleAndroidGmsPlayServicesWearable940Library
      :prepareComGoogleFirebaseFirebaseAnalytics940Library
      :prepareComGoogleFirebaseFirebaseAnalyticsImpl940Library
      :prepareComGoogleFirebaseFirebaseAuth940Library
      :prepareComGoogleFirebaseFirebaseAuthCommon940Library
      :prepareComGoogleFirebaseFirebaseAuthModule940Library
      :prepareComGoogleFirebaseFirebaseCommon940Library
      :prepareComGoogleFirebaseFirebaseConfig940Library
      :prepareComGoogleFirebaseFirebaseCrash940Library
      :prepareComGoogleFirebaseFirebaseDatabase940Library
      :prepareComGoogleFirebaseFirebaseDatabaseConnection940Library
      :prepareComGoogleFirebaseFirebaseIid940Library
      :prepareComGoogleFirebaseFirebaseMessaging940Library
      :prepareComGoogleFirebaseFirebaseStorage940Library
      :prepareComGoogleFirebaseFirebaseStorageCommon940Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseAssets
      :mergeReleaseResources
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      :compileReleaseSources
      :prePackageMarkerForRelease
      :transformClassesWithDexForRelease FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 21.061 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:87:13)
        at ChildProcess.emit (events.js:172:7)
        at maybeClose (internal/child_process.js:818:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
