3 Replies Latest reply on Sep 12, 2016 12:07 AM by levi23
    copy text to the clipboard or retrieve text from the clipboard.
    levi23 Level 1
      Hello everyone. I would ask if it is possible to copy a text to the clipboard content from a javascript illustrator.
      I also like to do the operation in reverse. retrieve text from the clipboard as a variable to use.
      I have read on the Internet could be done by Bat or AppleScript files but I have been tested and have not gotten it to work.
      It could run both Windows and Mac? It is possible?
      I would appreciate any help. Keep looking information
      Many thanks
      a greeting
        • 1. Re: copy text to the clipboard or retrieve text from the clipboard.
          levi23 Level 1
          Hello such.
          I've been looking information and have found a method that should work, but I'm not able to do.
          The process would create a txt file and a file ejectutable (MAC) (command ?? sh?) And using this file created dynamically txt copy the contents to clipboard
          Could anyone help me, please?
          I am a novice in these matters, and even more in what refers to MAC
          I guess it would be like a windows bat file, but I searched information but I do not know how to dynamically create and run it on Mac
          Thank you very much.
          A greeting. Excuse my English
          var doc = app.activeDocument;
          var text = doc.textFrames[0].contents;
          //alert(text)
          copyTextToClipboard2(text)
          function copyTextToClipboard2(text){
              var folderForTempFiles = '~/Desktop';
              var clipTxtFile = new File(folderForTempFiles + "/ClipBoardMac.txt");
              clipTxtFile.open('w');
              clipTxtFile.encoding = "UTF-8";
              clipTxtFile.lineFeed = "Unix";
              clipTxtFile.write(text);
              clipTxtFile.close();
              var clipBatFile = new File(folderForTempFiles + "/ClipBoard.command");
              if (clipBatFile.exists) {
                  clipBatFile.remove();
              clipBatFile.open('w');
              //clipBatFile.writeln("cat \"" + folderForTempFiles + "/ClipBoard.txt\"|clip");
              //clipBatFile.write("cat " + folderForTempFiles + " | pbcopy");
              clipBatFile.writeln("#!/bin/bash"+"\n"+"cat " + folderForTempFiles + "/ClipBoardMac.txt" + " | pbcopy");
              clipBatFile.close();
              clipBatFile.execute();
          • 2. Re: copy text to the clipboard or retrieve text from the clipboard.
            Ten A Adobe Community Professional
            Why don't you use copy and paste methods like below?
            function copytxt(){
              if (app.selection.length==1&&app.selection[0].typename=="TextFrame")
              app.copy();
            function getclipboardtxt(){
              app.paste();
              var tx = app.activeDocument.textFrames[0].contents;
              app.activeDocument.textFrames[0].remove();
              return tx;
            • 3. Re: copy text to the clipboard or retrieve text from the clipboard.
              levi23 Level 1
              thanks for your answer but my intent is to copy the unformatted text
              a greeting
