I'd be grateful if somebody could please help me out with
this problem.
I actually want to write the following using the IIF
statement:
<cfif temp gt 0>
<cfset label = "Over">
<cfelseif temp lt 0>
<cfset label = "Under">
<cfelse>
<cfset label = "-">
</cfif>
Note
If I output the variable label using the cfif, cfelseif and
cfelse, it gives me the correct output, i.e. either "-", Over, or
Under.
I tried the following to rewrite the above statement using
the iif function:
<cfset label = iif(temp eq 0,DE("-"),(iif(temp gt
0,DE("Over"),DE("Under"))))>
Now, when temp eq 0, it works fine.
However, when temp is lt 0, it throws me an error message
saying variable Under is undefined.
And when temp is gt 0, I get the same error message, but in
this case it says variable Over is undefined.
However, if I replace Over and Under by 1 or 0 (i.e.
integers) it works perfect!
Any idea how to get the output either Over or Under using the
iif statement pls?
Thanks and regards,
Yogesh Mahadnac.
