2 Replies Latest reply on May 16, 2006 5:11 PM by Newsgroup_User
    POI-HSSF problem.  saves in /runtime/bin, not /wwwroot
    DaveF67
      I am trying to get this to work in Solaris/Apache/MX7. When I run the code, it always saves the files in
      <cfusionserver>/runtime/bin/
      with owner "nobody|other"
      i need the files to read and write from
      <cfusionserver>/wwwroot/
      owner "www|www"
      any suggestions?
      files located in <cfserver>/WEB-INF/lib/
      -rw-r--r-- 1 www www 802216 May 16 09:42 poi-2.5.1-final-20040804.jar
      -rw-r--r-- 1 www www 55209 May 16 09:42 poi-contrib-2.5.1-final-20040804.jar
      <CFSCRIPT>
      workBook=createObject("java","org.apache.poi.hssf.usermodel.HSSFWorkbook").init();
      newSheet=workBook.createSheet();
      workBook.setSheetName(0, "My First Sheet");
      row=newSheet.createRow(55);
      cell=row.createCell(0);
      cell.setCellValue("hello world!");
      fileOutStream = createObject("java","java.io.FileOutputStream").init("test6.xls"); // ****** output
      workBook.write(fileOutStream);
      fileOutStream.close();
      </CFSCRIPT>
      I have tried using .init("/opt/coldfusionmx7/wwwroot/test6.xls"); but i get an error.
      Thanks if you can help
      Dave
        • 1. Re: POI-HSSF problem.  saves in /runtime/bin, not /wwwroot
          Level 7
          what error do you get when trying the init("/opt....")?
          that's on the right track...just using the filename itself is definitely not
          what you want.
          what you might do to get the full path you're looking for is create a file
          in wwwroot and do a
          <cfoutput>#getDirectoryFromPath(getCurrentTemplatePath())#</cfoutput>
          that'll tell you what coldfusion thinks it is, and from there you should
          have what you need to pass into the file init
          "DaveF67" <webforumsuser@macromedia.com> wrote in message
          news:e4d0n6$6vh$1@forums.macromedia.com...
          >it
          > owner "www|www"
          > any suggestions?
          > <CFSCRIPT>
          > fileOutStream =
          > output
          > </CFSCRIPT>
          > get an
          > error.
          > Dave
          • 2. Re: POI-HSSF problem.  saves in /runtime/bin, not /wwwroot
            Level 7
            also, you might try creating a file object first, initing that with your
            full path, and then passing that object into the init method of the output
            stream
            "Marc E" <cf@hifiwebdesign.com> wrote in message
            news:e4dlop$3t4$1@forums.macromedia.com...
            > not what you want.
            > in wwwroot and do a
            >>code, it
            >> owner "www|www"
            >> any suggestions?
            >> <CFSCRIPT>
            >> fileOutStream =
            >> output
            >> </CFSCRIPT>
            >> get an
            >> error.
            >> Dave
