1 Reply Latest reply on Sep 9, 2016 12:50 AM by Nanaky
    Error! Check Activation/Cannot Deauthorize
    judys70364405
      Got Error! Check Authorization.  Tried to deauthorize using correct password, but error message said to try later.  Am a computer novice - what can be done?  Using windows 8.1, downloaded latest version of ADE in effort to fix problem.
        • 1. Re: Error! Check Activation/Cannot Deauthorize
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
