3 Replies Latest reply on Sep 11, 2016 1:03 PM by try67
    Need help creating a searchable form that return all values on that row
    JimmyArthur
      I have a pdf document that lists every single zip code in the USA and for each row, it has five columns of information for each zip.  Using the built-in Search, when the user keys a zip code, the cursor jumps to that page and highlights only the zip code, making it difficult to read the other five columns.
      Not sure if this is possible, but it would be the ideal solution:
      Enter Zip Code:      ___________ [Search]  <-- User keys a zip code, if found, return all the columns in the same row in the report below
      Group:                    ___________
      Group Description: ____________
      Mkt Area                 ____________
      City                         ____________
      State                      ___
        • 1. Re: Need help creating a searchable form that return all values on that row
          "Return" how, exactly? Also, do you have this information available in a more accessible format, like a spreadsheet? If so, then it can probably be done using a custom-made script.
          • 2. Re: Need help creating a searchable form that return all values on that row
            JimmyArthur Level 1
            Thank you for looking into it.  I do have a spreadsheet, but was hoping to distribute a pdf file instead.  Both XLS and PDF look exactly the same.  The pdf is about 450 pages long with an index on Zip code.
            Zip     Group       Group Description            Mkt Area               City                              State
            00501    A           Group A - Description          Mkt-A               HOLTSVILLE                NY
            01002    A           Group A - Description          Mkt-A              AMHERST                      MA
            01014    A           Group A - Description          Mkt-A              CHICOPEE                    MA
            01030    B           Group B - Description          Mkt-B              FEEDING HILLS            MA
            01034    B           Group B - Description          Mkt-B             GRANVILLE                   MA
            01035    C           Group C- Description          Mkt-C             HADLEY                         MA
            01037    C           Group C - Description         Mkt-C             HARDWICK                    MA
            When I key 01030 in the Search box, the cursor jumps to the 4th row, highlighting only the zip code, making reading of the other columns a bit hard on the user.
            Short of writing an Excel macro, I was hoping I could add a blank page as page 1 and then add the fields listed above...
            Enter Zip Code:       01030 [Find]  <-- User keys 01030 and presses [Find], at which point we display:
            Group:                    A
            Group Description:  Group A Description
            Mkt Area                 Mkt-A
            City                         Feeding Hills
            State                       MA
            • 3. Re: Need help creating a searchable form that return all values on that row
              This can be done (entirely in the PDF), but it requires a custom-made script.
              The data from the spreadsheet will have to be converted to a plain-text file and attached to the PDF, and then the script could read it and populate the fields based on it.
              If you're interested in hiring someone to develop this script for you, feel free to contact me privately at try6767 at gmail.com
