4 Replies Latest reply on Dec 22, 2017 2:42 AM by amirtha_rajan
    Generate pdf from a blob data
    likusoft Level 1
      Hello
      with my PhoneGap app I make an ajax call to a backend service that generates a pdf file and returns a stream of these binary data . It is possible generate and save a pdf file on my device with this data. There is a special plugin ?
      Angelo
        • 1. Re: Generate pdf from a blob data
          VectorP Level 4
          Do you really want to re-generate a pdf locally, if the server already creates a pdf file?
          You can download it from the server using the Download method of cordova-plugin-file-transfer
          • 2. Re: Generate pdf from a blob data
            likusoft Level 1
            Thanks..
            This ajax call:
            var xhr = new XMLHttpRequest();
            xhr.open('GET', appPb.proxyUrl+"stampaaltro?idLancio="+id+"&isXls="+isXls+"&rpt="+tipo_report, true);
            // Hack to pass bytes through unprocessed.
            xhr.overrideMimeType('text/plain; charset=x-user-defined');
            xhr.onreadystatechange = function(e) {
              if (this.readyState == 4 && this.status == 200) {
                var binStr = this.responseText;
                for (var i = 0, len = binStr.length; i < len; ++i) {
                  var c = binStr.charCodeAt(i);
                  //String.fromCharCode(c & 0xff);
                   result = c & 0xff;  // byte at offset i
                  alert(result);
            xhr.send();
            returns the following binary data like (like a pdf)
            IT IS POSSIBLE create a file with the extension pdf
            %PDF-1.4
            5 0 obj
            <</Length 6 0 R/Filter /FlateDecode>>
            stream
            xWM6 WR@ l3>&m"[d7n/E lUl %Q )n7 = 4! K)K B{[/P5C ["C  ! _* Br}_TO|V wbWq.8   Rm5 k} `J (|[ _ H/\0bjW\<_
            Jn6 ab
            p[ +&9 wCZy g.
            4 2z Z 'lu}t)'UuSC! a S
            -t
            q VH"ba^Cs<m m=m?4w] xl 6]n Mst5
            S  [  Z r  )9I @Q 1  S 4dJ    e2E`1\gN(P Cz 
            LAl 0
            hM n2? R IZhG{SN(  
            +<_oH  ^ c)^
            E0X9CR  1$ ,aa;X7qH :.7u.]q?yP 9SKz rDPv   r RJ 2wa'WW E`  5))T5k dRq=Y- GPjw+fM
            3 lY<K    i+= I{KoJ H  > /b1`W_T1h `T1=   B8+{\*68dgFI [g(J  cX4uL" .
            • 3. Re: Generate pdf from a blob data
              VectorP Level 4
              Well, you could store the stream data using the File plugin (not as pdf, but simply as raw data), then display the data using a data URI.
              See for instance: jquery - How to build PDF file from binary string returned from a web-service using javascript - Stack Overflow
              • 4. Re: Generate pdf from a blob data
                amirtha_rajan
                have the same problem, did you get any solution ??
