2 Replies Latest reply on Sep 15, 2016 8:45 AM by jonathanl85551599
    How to correctly add a PANTONE swatch in Illustrator with Extendscript?
    jonathanl85551599 Level 1
      Hello,
      I'm working on a script to generate several files in a printing process:
      - a file which contains a single item of the imposition
      - a file which contains the proof of the item (to send to customer)
      - a file which contains the imposition of items to print
      To automate a maximum the different actions of the process, I would like to add all the colors which are used on the printing item in the swatches of each generated files. I can have orders only in CMYK, or in CMYK plus 1, 2, or 3 PANTONE colors.
      There is no problem for me to add CMYK colors or custom colors built from CMYK tints in document swatches, but I don't know how I can add a PANTONE color in swatches. In fact, I generate blank files with all "parameters" I need to work correctly, and when all files are generated, I work only on the single item file (single item file which is imported by my script into the imposition file and the proof file).
      So my question is the following : to add a PANTONE color in swatches, is it better to "generate" it with CMYK colors (and add it in swatches like a ColorModel.SPOT) or is it possible (and probably better) to add it from the PANTONE library?
      For example I add my custom spot colors with this function:
      function addSpot(name,c,m,y,k){
          try {
              swatch = app.activeDocument.swatches[name];
              addSpot (name+='1', c, m, y, k);
          catch (e) {
              var newSpot = app.activeDocument.spots.add();
              newSpot.name = name;
              var newColor = new CMYKColor();
              newColor.cyan = c;
              newColor.magenta = m;
              newColor.yellow = y;
              newColor.black = k;
              newSpot.colorType = ColorModel.SPOT;
              newSpot.color = newColor;
              var newSpotColor = new SpotColor();
              newSpotColor.spot = newSpot;
      What's the best way to add a PANTONE color in document swatches, even if the document have no element?
      Thanks a lot in advance for your replies
      Jo
