1 Reply Latest reply on Sep 9, 2016 10:45 AM by kerrishotts
    Move project from PhoneGap Build to local build with CLI
    GS-TG
      Hello,
      I wanted to ask, if anyone moved his or her project from PGB to a local phonegap-cli build machine. If yes, any tips are appreciated!
      My build machine is configured correctly, but I specifically wanted to ask about necessary project structure changes.
      Thanks in advance!
        • 1. Re: Move project from PhoneGap Build to local build with CLI
          kerrishotts Adobe Employee
          Config.xml is located in a different location in PGB vs. the local CLI. When converting from PGB to local CLI, do something like the following:
          1. Create a project using the CLI with the same name & ID:
              phonegap create test com.example.test test
          2. Copy your PGB files to the new project's www directory:
              cd ./test/www
              cp -r /path/to/PGB/files/*.* .
          2. Move config.xml from www to the parent directory:
              mv config.xml ../config.xml
          3. Move any splash/icon resources to the parent directory:
              mv res ../res
          4. Edit config.xml so that any path references (icons/splashes) are correct.
          5. Build the app and test, test, test!
          Hope that helps.
