14 Replies Latest reply on Jan 16, 2018 8:44 AM by ggraham123
    How do I read variable in JSON file?
    jiggy1965 Level 1
      As a test I've got this JSON file called info.js:
      var JSONObject = '{"page_text" : "This a normal string that can be used."}'
      Now in my Animate CC file I want to read that 'page_text' variable so I can put its content, the string, in a text field. I started with this:
      // load JSON file
      var req = new XMLHttpRequest();
      req.open("GET", "info.js", true);
      req.addEventListener("load", transferComplete);
      req.send();
      //output JSON file
      function transferComplete(e) {
          var JSONObject= JSON.parse(e.target.response);
        console.log(JSONObject);
      This should read the info.js file. Which works. Then it should output the contents of the JSON file in the console. Without that JSON.parse it outputs the entire contents as a string. So it kind of works, loading the JSON file and outputting the entire contents.
      But I wish the output the content of the page_text variable. So I was thinking the first thing I'd have to do is to JSON parse  it. But then it outputs: 'Uncaught SyntaxError: Unexpected token v in JSON at position 0'. Don't know what I'm doing wrong/
      How to I make it output "This is a normal string that can be used."?
