1 Reply Latest reply on Sep 10, 2016 5:07 AM by karthiks94217840
    loop through each xml element in xml file using extendscript toolkit cs6
    aviR Level 1
      hii all
      I have an xml like:
      <root>
      <seq path="chapter02/ch02_reader_0.html"/>
        <seq path="chapter02/ch02_reader_1.html"/>
        <seq path="chapter02/ch02_reader_2.html"/>
        <seq path="chapter02/ch02_reader_3.html"/>
      </root>
      How can i read the value of the path attribute in extendscript?
      I am able to read the file using File.read()
      But how do i get the path attribute values?
      Please suggest
        • 1. Re: loop through each xml element in xml file using extendscript toolkit cs6
          karthiks94217840 Level 2
          Try this.
          You got the all attributes value in the text file.
          var main = function(){
            var doc = app.properties.activeDocument,
            xmlFile = File ( Folder.temp+"/attr.xml" ),
            xmlObject,
            xmlAttrs, attrs = [], n = 0, i = 0,
            sep = "\t";
            if (!doc) return;
            doc.exportFile ( ExportFormat.XML, xmlFile );
            if ( !xmlFile.exists ) {
            alert("Unable to read xml data");
            return;
            xmlFile.open('r');
            xmlObject = XML ( xmlFile.read() );
            xmlFile.close();
            xmlFile.remove();
            xmlAttrs = xmlObject.xpath("//*//@*");
            n = xmlAttrs.length();
            while ( i<n ) {
            attrs [ attrs.length ] = xmlAttrs[i].name()+sep+xmlAttrs[i];
            i++;
            if ( !attrs.length ) {
            alert("Could'nt find any attributes.");
            return;
            writeFile ( "Attribute Name"+sep+"Attribute Value"+"\r"+attrs.join("\r") );
          var writeFile = function( data ) {
            var file = File ( Folder.desktop+"/attributes.csv" );
            file.open("w");
            file.write ( data );
            file.close();
            file.execute();
          main();
          KS
