3 Replies Latest reply on Sep 12, 2016 10:08 AM by kerrishotts
    android AdMob SDK deprecation, i need help to undestand which version i am running
    piergiorgiop12572091
      Hi to all,
      my app is currelty using this plugin to implement ads by admob:
      com-admob-plugin-pgp
      this is the manifest of the plugin:
      <?xml version="1.0" encoding="UTF-8"?>
      <plugin xmlns="http://apache.org/cordova/ns/plugins/1.0"
              xmlns:android="http://schemas.android.com/apk/res/android"
              id="com-admob-plugin-pgp"
              version="1.0.1">
          <name>Admob Plugin PGP</name>
          <keywords></keywords>
          <description>Basato sulla versione 5.4.0 di com-admob-plugin</description>
          <license>Apache 2.0 License</license>
          <repo>https://github.com/admob-google/admob-cordova</repo>
        <issue>https://github.com/admob-google/admob-cordova/issues</issue>
          <engines>
              <engine name="cordova" version=">=3.0" />
          </engines>
          <js-module src="www/admob.js" name="admob">
              <clobbers target="window.admob"/>
          </js-module>
          <platform name="android">
              <config-file target="res/xml/config.xml" parent="/*">
                  <feature name="admob" >
                      <param name="android-package" value="com.admob.cordova.plugin.AdmobAdPlugin"/>
                  </feature>
              </config-file>
              <config-file target="AndroidManifest.xml" parent="/manifest/application">
                 <!--<meta-data  android:name="com.google.android.gms.version"   android:value="8115000"/>-->
        <activity  android:name="com.google.android.gms.ads.AdActivity"  android:configChanges="keyboard|keyboardHidden|orientation|screenLayout|uiMode|screenSize |smallestScreenSize"/>
              </config-file>
              <config-file target="AndroidManifest.xml" parent="/*">
                   <uses-permission android:name="android.permission.INTERNET"/>
           <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>
           <uses-permission android:name="android.permission.ACCESS_WIFI_STATE"/>
              </config-file>
              <source-file src="src/android/libs/admobadplugin.jar" target-dir="libs/"/>
              <!--<source-file src="src/android/libs/google-play-services.jar" target-dir="libs/"/>-->
              <framework src="com.google.android.gms:play-services-ads:+" />
          </platform>
          <platform name="ios">
              <config-file target="config.xml" parent="/*">
                  <feature name="admob">
                      <param name="ios-package" value="AdmobAdPlugin"/>
                  </feature>
              </config-file>
              <source-file  src="src/ios/AdmobAdPlugin.m"/>
              <header-file  src="src/ios/AdmobAdPlugin.h"/>
              <framework src="src/ios/AdmobAPI.framework" custom="true"/>
           <framework src="EventKit.framework"/>
              <framework src="EventKitUI.framework"/>
              <framework src="StoreKit.framework"/>
              <framework src="AdSupport.framework"/>
              <framework src="MessageUI.framework"/>
              <framework src="AVFoundation.framework"/>
              <framework src="Foundation.framework"/>
              <framework src="UIKit.framework"/>
              <framework src="CoreGraphics.framework"/>
              <framework src="SystemConfiguration.framework"/>
              <framework src="AudioToolbox.framework"/>
          </platform>
      </plugin>
      how can i know which version of admob SDK (or google play service) i'm running with it?
