13 Replies Latest reply on Jun 15, 2018 6:45 AM by roger.truss
    SCUP catalog for Adobe AIR
    jyothi289 Level 1
      Location for SCUP catalog for Adobe AIR
        • 1. Re: SCUP catalog for Adobe AIR
          Destr@ Adobe Employee
          Sorry, We do not deploy update via scup for Adobe Air.
          • 2. Re: SCUP catalog for Adobe AIR
            jyothi289 Level 1
            Thank you for the response, how do we update AIR future updates?
            • 3. Re: SCUP catalog for Adobe AIR
              Via Background update:
              if users have old Adobe AIR, they get a pop-up.
              • 4. Re: SCUP catalog for Adobe AIR
                jyothi289 Level 1
                We want to avoid this since all users do not have Admin rights, is there a recommended method to deploy the future updates automatically?
                • 5. Re: SCUP catalog for Adobe AIR
                  As of now we do not have any silentUpdate mechanism for Adobe AIR update other than the one mentioned above.
                  We will take your feedback and share with the team.
                  • 6. Re: SCUP catalog for Adobe AIR
                    jyothi289 Level 1
                    Ok, please do. Many other companies and Techs are looking for SCUP catalog for AIR. Will be beneficial if it is developed.
                    • 7. Re: SCUP catalog for Adobe AIR
                      saschao25393384
                      Any news on that? We also use SCUP for updating Flash and Acrobat, it would be a great benefit to update AIR and Shockwave the same way.
                      Regards Sascha
                      • 8. Re: SCUP catalog for Adobe AIR
                        roger.truss
                        I have been manually building scup data every month for air for years.
                        #  Roger Truss 9-24-2014
                        #  Brunswick Corporation
                        ### most important first step!!!!!!!! ###
                        Grab the installer from the Download URL: step below and extract the files to get the actual version from the embedded dll.
                        also get the msi as its needed for app creation in CM12.
                        7-zip or winrar work well for this.
                        ######      SCUP build info      ######
                        Download URL:
                        http://airdownload.adobe.com/air/win/download/latest/AdobeAIRInstaller.exe
                        Save the downloaded exe  here:
                        \\some path\Adobe\Air\current version #
                        \\some path\Adobe\Air\Scup (overwrite = yes)
                        ##Package Information Section##
                        Package Source: AdobeAIRInstaller.exe
                        point to
                        \\some path\Adobe\Air\scup\AdobeAIRInstaller.exe
                        Download URL section:
                        Command Line:
                        -silent -eulaAccepted
                        ##Required Information Section##
                        Language:==duh
                        Title: Adobe Air appropriate version info
                        Description: autopopulates with title
                        Classification: Usually Security
                        Vendor: Adobe Systems, Inc.
                        Product: Adobe Air
                        More info URL:http://www.adobe.com/products/air.html
                        ##Installable Rules Section""
                        (need 2 one for x64 and one for x86 based OSes):
                        File:
                        Common Paths: PROGRAM_FILES_COMMONX86
                        Path: Adobe AIR\Versions\1.0
                        File Name: Adobe AIR.dll
                        File must exist and be less than
                        ##Installed Rules Section""
                        File:
                        File must exist and must >= the current version
                        The last 2 sections should have a layout like this and are used in teh app deploymetn ofthe product in CM12:
                        AND
                          OR
                            File '[PROGRAM_FILES_COMMONX86]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version (< for installable rules and >= for installed rules) 'current version'
                          OR
                            File '[PROGRAM_FILES_COMMON]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version (< for installable rules and >= for installed rules) 'current version'
                        • 9. Re: SCUP catalog for Adobe AIR
                          saschao25393384 Level 1
                          Hi Roger,
                          thank you. I rebuild it but havent test it yet. After first look i thought omg wtf but during building its seems pretty easy - with that type of package .
                          But i have one/two questions regarding installable rules/installed rules because i cant edit like you have. If i try to add the first "OR" its saying "invalid rule". If i remove it then its good. If i think about it also should work with the first "OR", or? this is what i have eg. inst
                          AND
                              File '[PROGRAM_FILES_COMMONX86]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version < '25.0.0.134'
                            OR
                              File '[PROGRAM_FILES_COMMON]\Adobe AIR\Versions\1.0\Adobe AIR.dll' Version < '25.0.0.134'
                          • 10. Re: SCUP catalog for Adobe AIR
                            failure and "OK" is greyed out
                            now it would be accepted
                            • 11. Re: SCUP catalog for Adobe AIR
                              if i try to publish it, errors occurs, SCUP.log:
                              PublishItem: --- Digest verification failed on content for software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-    a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'.    Updates Publisher    17.03.2017 18:02:38    4 (0x0004)
                              PublishItem: --- Publish of software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' has FAILED.    Updates Publisher    17.03.2017 18:02:38    4 (0x0004)
                              If i activate in "package information" "use a local source to publish..." instead of the mentioned URL "http://airdownload.adobe.com/air/win/download/latest/AdobeAIRInstaller.exe it was succesfully published. Any clue on that?
                              SCUP.log with URL:
                              WizardBase: closing Publish Software Updates Wizard wizard.    Updates Publisher    17.03.2017 18:00:22    1 (0x0001)
                              Updates workspace: publish wizard completed.    Updates Publisher    17.03.2017 18:00:25    1 (0x0001)
                              Updates workspace: Starting edit wizard for update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')''    Updates Publisher    17.03.2017 18:00:27    1 (0x0001)
                                       WizardBase: closing Edit Software Update Wizard wizard.    Updates Publisher    17.03.2017 18:02:28    1 (0x0001)
                              Updates workspace: edit wizard completed.    Updates Publisher    17.03.2017 18:02:31    1 (0x0001)
                              Updates workspace: Starting publish wizard with 1 updates.    Updates Publisher    17.03.2017 18:02:34    1 (0x0001)
                                       Publish: Preparing list of selected updates for publishing.    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                                       Connecting to a local update server with locally detected settings.    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                                       Publish: Update server name: servername    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                                       Publish: Publish operation starting for 1 updates.    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                                       Publish: Publish: Verifying update server is configured with a certificate prior to publishing.    Updates Publisher    17.03.2017           18:02:37    4 (0x0004)
                                       Publish: Publish: Update server appears to be configured with a certificate.    Updates Publisher    17.03.2017 18:02:37    4           (0x0004)
                                       Building dependency graph for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190'           Vendor:'Adobe Systems, Inc.' Product:'AIR')'    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                                       No dependencies found for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe           Systems, Inc.' Product:'AIR')'    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                              Found total of 0 dependencies (may include duplicates).    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                              PublishItem: Update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.'           Product:'AIR')'' has no dependencies.    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                              PublishItem: Publishing update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems,           Inc.' Product:'AIR')'.    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                              PublishItem: --- Evaluating software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe           Systems, Inc.' Product:'AIR')' for publishing as FullContent.    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                              PublishItem: --- Software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems,           Inc.' Product:'AIR')' needs to be published with full content.    Updates Publisher    17.03.2017 18:02:37    4 (0x0004)
                              PublishItem: Retrieving content for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe           Systems, Inc.' Product:'AIR')'.    Updates Publisher    17.03.2017 18:02:38    4 (0x0004)
                              PublishItem: --- Content will be saved to C:\Users\xxx\AppData\Local\Temp\\dguf3hvh.wnh\Adobe AIR Installer.exe.    Updates Publisher    17.03.2017 18:02:38    4 (0x0004)
                              PublishItem: Download Content: file was downloaded successfully.    Updates Publisher    17.03.2017 18:02:38    4 (0x0004)
                              PublishItem: Successfully retrieved content for software update 'Adobe Air 25.0.0.134 (
                                        UpdateId:'75ddd054-  a640-4e85-          a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')' to local file:
                                        C:\Users\xxx\AppData\Local\Temp\\dguf3hvh.wnh\Adobe AIR Installer.exe    Updates Publisher    17.03.2017 18:02:38    4           (0x0004)
                              PublishProgress: Publish operation completed.    Updates Publisher    17.03.2017 18:02:38    4 (0x0004)
                              Publish: Background processing completed.    Updates Publisher    17.03.2017 18:02:38    1 (0x0001)
                              SCUP.log with local source:
                              WizardBase: closing Publish Software Updates Wizard wizard.    Updates Publisher    17.03.2017 18:03:48    1 (0x0001)
                              Updates workspace: publish wizard completed.    Updates Publisher    17.03.2017 18:03:50    1 (0x0001)
                              Updates workspace: Starting edit wizard for update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')''    Updates Publisher    17.03.2017 18:03:53    1 (0x0001)
                                  WizardBase: closing Edit Software Update Wizard wizard.    Updates Publisher    17.03.2017 18:04:09    1 (0x0001)
                              Updates workspace: edit wizard completed.    Updates Publisher    17.03.2017 18:04:12    1 (0x0001)
                              Updates workspace: Starting publish wizard with 1 updates.    Updates Publisher    17.03.2017 18:04:14    1 (0x0001)
                                  Publish: Preparing list of selected updates for publishing.    Updates Publisher    17.03.2017 18:04:20    4 (0x0004)
                                  Connecting to a local update server with locally detected settings.    Updates Publisher    17.03.2017 18:04:20    4 (0x0004)
                                  Publish: Update server name: servername    Updates Publisher    17.03.2017 18:04:20    4 (0x0004)
                                  Publish: Publish operation starting for 1 updates.    Updates Publisher    17.03.2017 18:04:20    4 (0x0004)
                                  Publish: Publish: Verifying update server is configured with a certificate prior to publishing.    Updates Publisher    17.03.2017      18:04:20    4 (0x0004)
                                  Publish: Publish: Update server appears to be configured with a certificate.    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                                       Building dependency graph for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190'           Vendor:'Adobe           Systems, Inc.' Product:'AIR')'    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                                       No dependencies found for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                              Found total of 0 dependencies (may include duplicates).    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                              PublishItem: Update ''Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.'           Product:'AIR')'' has no dependencies.    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                              PublishItem: Publishing update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems,           Inc.' Product:'AIR')'.    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                              PublishItem: --- Evaluating software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe           Systems, Inc.' Product:'AIR')' for publishing as Automatic.    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                              PublishItem: --- Software update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190' Vendor:'Adobe Systems,            Inc.' Product:'AIR')' needs to be published (no content).    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                              PublishItem: --- Metadata only SDP XML file for publishing created at C:\Users\xxx\AppData\Local\Temp\tmpB3E.tmp    Updates           Publisher    17.03.2017 18:04:21    4 (0x0004)
                              PublishItem: ---Using default return codes for update...    Updates Publisher    17.03.2017 18:04:21    4 (0x0004)
                              PublishItem: --- Calling update server API for publishing update 'Adobe Air 25.0.0.134 (UpdateId:'
                                        75ddd054-a640-4e85-    a68f-c153e8ef0190' Vendor:'Adobe Systems, Inc.' Product:'AIR')'    Updates Publisher    17.03.2017           18:04:21    4 (0x0004)
                              PublishItem: --- PublishPackage call successful for update 'Adobe Air 25.0.0.134 (UpdateId:'75ddd054-a640-4e85-a68f-c153e8ef0190'           Vendor:'Adobe Systems, Inc.' Product:'AIR')'    Updates Publisher    17.03.2017 18:04:22    4 (0x0004)
                              PublishProgress: Publish operation completed.    Updates Publisher    17.03.2017 18:04:22    4 (0x0004)
                              Publish: Background processing completed.    Updates Publisher    17.03.2017 18:04:22    1 (0x0001)
                              WizardBase: closing Publish Software Updates Wizard wizard.    Updates Publisher    17.03.2017 18:04:25    1 (0x0001)
                              Updates workspace: publish wizard completed.    Updates Publisher    17.03.2017 18:04:28    1 (0x0001)
                              Thank you. Published it anyway and lets wait for SCCM recognition how much devices will need it
                              • 12. Re: SCUP catalog for Adobe AIR
                                roger.truss Level 1
                                So sorry for the super long delay, looks like notifications for this chain I am not getting.  The first OR was a typo, sorry about that.  As to the publication error that is because the source file you used was not the same as what was on the web.
