1 Reply Latest reply on Sep 12, 2016 7:24 AM by ohmnath
    Error in downloading Image using boost library.
    SiddheshK09 Level 1
      Hi All,
          We are trying to download the image file from the server using Indesign boost libraries(Indesign CC2014 sdk). But it throws "read_until: End of file" exception. Please help me If anybody has tried it. My Code snippet is as below -
        boost::asio::io_service io_service;
        // Get a list of endpoints corresponding to the server name.
        tcp::resolver resolver(io_service);
        tcp::resolver::query query(serverName, sPortNo);
        tcp::resolver::iterator endpoint_iterator = resolver.resolve(query);
        tcp::resolver::iterator end;
        // Try each endpoint until we successfully establish a connection.
        tcp::socket socket(io_service);
        boost::system::error_code error = boost::asio::error::host_not_found;
        while (error && endpoint_iterator != end)
        socket.close();
        socket.connect(*endpoint_iterator++, error);
        boost::asio::streambuf request;
        std::ostream request_stream(&request);
        request_stream << "GET " << assetUrl << " HTTP/1.1\r\n";
        request_stream << "Host: " << serverName << ":" << sPortNo << "\r\n";
        request_stream << "Connection: close\r\n";
        request_stream << "Accept: */*\r\n";
        request_stream << "Cookie: JSESSIONID=" << sTokenkey << "\r\n\r\n";
        // Send the request.
        int bytesSent = (int)boost::asio::write(socket, request);
        // Read the response status line.
        boost::asio::streambuf response;
        boost::asio::read_until(socket, response, "\r\n");  // throws an exception at this point.
      Thanks all in advance.
      Regards,
      Siddhesh
