1 Reply Latest reply on Sep 13, 2016 6:03 AM by davidblatner
    Reproducible Crash with Windows InDesign CC 2015.4
    PeteBaumgartner Level 1
      The script below opens up to 10 InDesign documents from a folder of more than 10 InDesign documents, makes a simple edit and then saves the document.
      If the InDesign documents reside on a networked file server - this will crash. If the InDesign documents reside on the local drive - this script runs fine. Have gotten the crash on Windows 8 and 10. On Macs runs fine.
      In addition if the script is edited to close the document - after each save - it will run okay over the network and locally.
      Does anyone have any idea what could be going on here - the issue seems to be editing multiple docs over the net and then leaving them open. But why?
      InDesign CC2015.4
      Thanks !
         pete
      //------------------  progress bar
      pg={};
      pg.newProgress = function (maxval, str) {
          pg.pBarMax = maxval + 1;
          pg.pb_win = new Window('palette', str);
          pg.pbar = pg.pb_win.add('progressbar', undefined, 1, pg.pBarMax);
          pg.pbar.preferredSize = [300, 20];
          pg.pbar.value = 0;
          pg.pb_win.show();
      pg.incProgress = function() {
          pg.pbar.value = pg.pbar.value + 1;
      pg.closeProgress = function () {
          try {
              pg.pb_win.close();
          catch (e) {
              $.writeln ("pg.closeProgress "+e);
      function getTheFolder () {
            var tmp=Folder.selectDialog ("Select folder of InDEsign documents");
            if (tmp instanceof Folder) return tmp;
            return false;
      function runTheBatch () {
          var fldr=getTheFolder();
          if (fldr==false) return;
          var i=0;
          var maxIterations  = 10;
          var myFileList=fldr.getFiles(/\.(indd)$/i);   // was (/\.(indd|indt)$/i)
          pg.newProgress  (maxIterations, "Test progress");
         do {
              for (var x=0; x<myFileList.length && i<maxIterations; x++) {
                  i++;
                  var fi = File(myFileList[x]);
                  if (fi instanceof File) {
                         app.scriptPreferences.userInteractionLevel=UserInteractionLevels.neverInteract;
                      var docRef = app.open(fi);
                      if (docRef instanceof Document){
                          doSomethingToDocument (docRef);
                          //docRef.close();
                           pg.incProgress();
                          $.writeln("Finished iteration "+i);
                      } else {
                          $.writeln ("Not a indd doc "+myFileList[x]);
                         app.scriptPreferences.userInteractionLevel=UserInteractionLevels.interactWithAll;
                  } else {
                      $.writeln ("Not a file "+myFileList[x]);
         } while (i <maxIterations );
         pg.closeProgress();
      function doSomethingToDocument (docRef) {
          try {
              docRef.insertLabel("dirty","myDirtyValue");
              docRef.save();
          } catch (e) {
              $.writeln("doSomethingToDocument exception "+e);
      runTheBatch();
      alert ('done');
