1 Reply Latest reply on Sep 29, 2016 11:59 PM by meenakshin83966505
    Renaming long filenames in iPad app
    mum61e
      In the iPad app, when I rename a file with a long filename, the rightmost part of the filename appears in the field. If there is a way to scroll the name so I can edit the left part of the filename, I can't find it.
      At present, I "Select All", copy the filename into the Notes app, edit it there and then copy it back, so something is clearly wrong.
      Is there a scrolling facility? If so, how does it work? If not, please may we have it?
        • 1. Re: Renaming long filenames in iPad app
          meenakshin83966505 Adobe Employee
          Hi mum61e,
          In the rename field, when you long press the file name, a circular glass appears that helps you to scroll left and right in that field.
          You can scroll and leave it where you wish to make changes in the name.
          Please make sure that once you long press, do not leave it till you get the exact place where you need to make changes.
          Let us know if you have any query.
          Regards,
          Meenakshi
