7 Replies Latest reply on Sep 14, 2016 6:06 AM by EddieLotter
    ColdFusion Report Building Grouping Output By Date
    j.a.c.i.
      I am building a report in cf report builder where there records outputed are grouped and sorted by date in the cf query
      I need to be able to display the date as the grouped heading on each page, if there is a change of date in results on the same page i am wanting the sub heading for the new grouped date to appear on the page as a sub heading.
      the output i am needing is the same as the output that would be generated from the following code in a cfm output
      <cfoutput query="queryname" group="TransactionDate">
      #TransationDate#<br>
           <cfoutput>
      #transationTime# , #transactiontype#, #transactionamount#
           </cfoutput>
      </cfoutput>
      When i try and generate similar output above in cf report builder i am not able to have the TransationDate appear as the subheading once the date changes
      the report simply outputs the rows containing
      however at the change of date there is no sub heading appearing to separate the transaction from one date to the next via a sub heading3
      Adise on how to solve this would be appreciated and or reference to any examples of a cfr file that does output its results in a grouped fashion within the one page as described above
