16 Replies Latest reply on Sep 16, 2016 9:57 AM by Laubender
    Dynamically adjusting text
    Karl B Cartwright Level 1
      InDesign CS 5 - Windows
      I am looking for suggestions for a solution.
      I have this format which includes one or two lines of text that appear inside brackets (Graphic elements) as shown.  The brackets will always be the same size and should "expand" to accommodate the text between them. (I know the example shows the brackets the same distance apart in both examples, but they should be ab
      For one line, I have placed the graphic elements inline with the text.  So when the text is edited, the brackets will expand as needed.  This works fine
      For two lines, the text needs to be smaller, but the brackets remain the same size as the single line of text.  Looking for an easy way to edit the text in this case so it works similarly to the single line of text.  Editing the text will allow the brackets to expand as needed.
        • 1. Re: Dynamically adjusting text
          Document Geek Adobe Community Professional
          You need to use anchored objects. Diane Burns wrote an article explaining how to do just that: http://indesignsecrets.com/the-burns-effect-using-anchored-objects-in-nonintuitive-ways.ph p
          • 2. Re: Dynamically adjusting text
            Obi-wan Kenobi Level 5
            Just for fun and just done with 3 different para styles:
            • 3. Re: Dynamically adjusting text
              Is this done with "The Burns Effect" as described above?
              • 4. Re: Dynamically adjusting text
                As I went through this, I realized that this is just what I am doing for the single line of text.  I just did not realize it was making an anchored object.  So yes, this works for the single line.
                Still looking for the other option, unless I am missing how to make this effect work for that case.
                • 5. Re: Dynamically adjusting text
                  George_Salnik Adobe Community Professional
                  Jedy! I'm repeat: show all, not only screenshot with ready image
                  • 6. Re: Dynamically adjusting text
                    Aha! You again! Would you be a Sith?
                    Here, I'm searching some specific para lengths (more than 120 chars but less than 135!
                    … But the op can just select a para and play it on "selection"!
                    • 7. Re: Dynamically adjusting text
                      Thank you for your reply.  I really appreciate your time in answering with screenshots.
                      The language difference in the program is making it a bit difficult to follow your steps.  I will continue as best I can, but I am not sure I will succeed.
                      It looks like you have used the Find/Change feature to find specific text to apply a paragraph style to, and this is not really necessary to achieve the effect you have described here.
                      If I understand you correctly, you have created 2 character styles. One to describe the base text, and one to describe the brackets.  You then have created a Paragraph Style which uses GREP to identify the two elements, and apply the character styles accordingly.
                      Unfortunately, I am not familiar enough with this approach to work out the details.  If you are able to provide further details on how each style is created, that would help.
                      Again, i really appreciate your time.
                      • 8. Re: Dynamically adjusting text
                        Hi Karl,
                        the brackets are text characters.
                        The first one is formatted with:
                        Character style 1:
                        56 pt size
                        0 leading
                        -25 baseline shift
                        the second bracket:
                        Character style 2
                        56 pt size
                        0 leading
                        +4 baseline shift
                        Paragraph style:
                        The indents are:
                        57 mm left, 47 mm right
                        To make room for the brackets:
                        -7 mm first line indent
                        -7 mm last line indent
                        There are two GREP styles that apply the formatting for the brackets by detecting a bracket at the beginning of a paragraph and one that will detect a bracket at the end of a paragraph. Also note, that the second bracket is parted from the text with a right aligned tab.
                        But this construct is also showing, that there is no real flexibility with InDesign if you consider a construction like this as part of a text flow. A different text size of the body text could break it, a different width of the text frame will break it and you have to readjust the indents, the baseline shift values as well.
                        Regards,
                        Uwe
                        • 9. Re: Dynamically adjusting text
                          Uwe,
                          As you said, It's an "ID construction" based on a para style (with a char size), a number of lines (3 here) and 2 char styles.
                          With variants based on the number of lines (~ the chars number), it's relatively cool to insert this kind of constructions in a text flow!
                          Thanks for the explanations!
                          • 10. Re: Dynamically adjusting text
                            Hi Obi-wan,
                            I'm not sure about Karl's setup of text frames. Maybe he is using his sample not with a paragraph flowing with a larger story.
                            Even if this is the case, would't it be easier to use anchored objects for the brackets and a simple "align center" for the text? The concept that is behind Diane Burns' blog post.
                            If the brackets and the text can stand alone on a page and not flowing with a story I would perhaps go for:
                            Plan B: Work with 3 text frames.
                            *(CS6 and above)
                            Frame 1 and 2 will hold the brackets. Could be text (glyphs you find in your font), anchored images or graphics; that will not matter.
                            Frame 3 is our text frame, that holds the main text and has some special features:
                            a. Text wrap
                            b. Automatic width (optional, but convenient if applied)*
                            Position the right edge of frame 1 to the horizontal center of frame 3.
                            Position the left edge of frame 2 to the horizontal center of frame 3.
                            Make sure that the width of frame 1 and 2 when added is the maximum width you would allow for the brackets surrounding your text.
                            It's more difficult to explain than to show.
                            Download an IDML file from my Dropbox account where I am showing this:
                            Dropbox - BracketsAroundTextFrame-FLEXIBLE.idml
                            And watch a movie where I am working with the 3 text frames (also on my Dropbox account):
                            Dropbox - BracketsAroundTextFrame-FLEXIBLE.mov
                            Here some screenshots from my German InDesign CS6 that are revealing a little bit of this:
                            1. Two text frames holding the brackets, one text frame for the main text:
                            2. No text frame between the two text frames holding the brackets:
                            3. Dragging another text frame with text wrap will part the two brackets:
                            Regards,
                            Uwe
                            • 11. Re: Dynamically adjusting text
                              Excellent!  Thank you for that explanation.  I really like this approach, Obi-wan.
                              Unfortunately, the design requires the brackets to be graphic elements.  But if I can convince the designer to change her design...
                              Thanks again!
                              • 12. Re: Dynamically adjusting text
                                Thank you Laubender
                                This is a great option for me.  It can be set up in the template, and the artists can edit the text as needed.  Changing the text size within the limits we specify and adjust leading if necessary.  In fact, there will probably be just two options for text sizes.  One for a single line item, and one for the two line item.  So we can set up some character styles for them to use for each case...
                                The easiest approach for the single line is the anchored objects.  But to give flexibility, we can set it up this way to accommodate either option... Or, perhaps give the options as separate layers...
                                Thanks again. This been a great discussion and I have learned a lot.
                                • 13. Re: Dynamically adjusting text
                                  Uwe and Karl, just for fun!
                                  Variable Brackets in InDesign - YouTube
                                  • 14. Re: Dynamically adjusting text
                                    More time now to answer!
                                    It's truly easy to do it like I show in the video above.
                                    1/ create a [width-height auto-sized] text frame and type what you want:
                                    To do the brackets, I use 2 tricks:
                                    2/ 4 anchored blocks, placed at each text frame corner but anchored at the beginning of the line:
                                    For the first anchored:
                                    For the others, duplicate the anchor 3 times and play with the 2 checkerboards in the screenshot above and the  (vertical/horizontal)-mirror effect.
                                    Note that the 4 anchors are locked!
                                    3/ The anchored element is a simple stroke with a gradient (!):
                                    More control on its aspect:
                                    Result:
                                    4/ The central part of the bracket can be done using 2 ways:
                                    a) using "Paragraph Border" (as here);
                                    b) Applying an effect to the text box [ID basic feature, on the left/right sides].
                                    No more!
                                    With this simple construction, the box works horizontally and vertically!
                                    We can type text (horizontally) with new lines (vertically)!  Cool!
                                    • 15. Re: Dynamically adjusting text
                                      Just for fun! [2]
                                      Another construction using 2 auto-resized text frames and … Grep! Just type you text!
                                      The trigger is a soft-return before "just".
                                      The background color and the shadow? It is to look pretty!
                                      • 16. Re: Dynamically adjusting text
                                        Hi Obi-wan,
                                        to trigger another point size with a GREP Style that reacts on a soft return \n is a cool idea.
                                        Best,
                                        Uwe
