3 Replies Latest reply on Sep 15, 2016 3:24 PM by Vfxvenkat98
    Make Background layer and top layer visible
    Vfxvenkat98 Level 1
      hi,
           How to save layersets along with Background layer and top layer.
      Here is the script to save current active layerset as .jpg format but when i try to use the (for loop) to save all the layersets  one by one bottom order it current turn off's the background layer and top layer.
      But i dont know how to run this via looping to make the active layer one by one along bottom and top layer
      Anyone help on this to fix this script
      #target photoshop;
      if (app.documents.length > 0) {
      var thedoc = app.activeDocument;
      // getting the name and location;
      var docName = thedoc.name;
      if (docName.indexOf(".") != -1) {var basename = docName.match(/(.*)\.[^\.]+$/)[1]}
      else {var basename = docName};
      // getting the location, if unsaved save to desktop;
      try {var docPath = thedoc.path}
      catch (e) {var docPath = "~/Desktop"};
      // jpg options;
      var jpegOptions = new JPEGSaveOptions();
      jpegOptions.quality = 12;
      jpegOptions.embedColorProfile = true;
      jpegOptions.matte = MatteType.NONE;
      //save jpg in layerset name:
      thedoc.saveAs((new File(docPath+'/'+thedoc.activeLayer.name+'.jpg')),jpegOptions,true);
      //thanks to xbytor;
        • 1. Re: Make Background layer and top layer visible
          Pedro Cortez Marques Level 3
          Hi. I hope it helps.
          #target photoshop;
                  var basename = docName.match(/(.*)\.[^\.]+$/)[1];
              } else {
                  var basename = docName;
              try {
              catch (e) {
              var layerSets_ = app.activeDocument.layerSets;
              for (var a =0; a < layerSets_.length; a++) {
                  // turn all layerSets invisible
                  for (var b =0; b < layerSets_.length; b++) {
                      layerSets_[b].visible = false;
                  layerSets_[a].visible = true;
                  // jpg options;
                  thedoc.saveAs(new File(Folder.desktop + '/backup/'+layerSets_[a].name+'.jpg'),jpegOptions,true);
                  //thanks to xbytor;
          • 2. Re: Make Background layer and top layer visible
            Quick Top and Bottom of a documents visibility ON will not change the visibility state of layes within top and botton  layer Groups.
            var layers = activeDocument.layers;
            layers[0].visible=true; // Top Layer or Layer Group
            layers[layers.length-1].visible=true;    // Background Layer or Bottom Layer or Group
            • 3. Re: Make Background layer and top layer visible
              Vfxvenkat98 Level 1
              Thanks a lot Pedro Cortez Marques,JJMack Pedro Cortez Marques
              But currently it processing all the layer sets in the active document if it is possible to unprocess a particular named group
              eg; in the document there is an layer group called Masks above this masks group all my actual layersets are there so basically i need to process all the groups above the masks group and not the layer groups below Masks layergroups.
