4 Replies Latest reply on Sep 15, 2016 5:41 AM by kerrishotts
    iOS10 and SVG image problem
    cemshid
      We are developing a PhoneGap ios application and had a big surprise when we update our phones to ios10.
      SVG images are not loading.
      Does anyone has an idea about this?
        • 1. Re: iOS10 and SVG image problem
          kerrishotts Adobe Employee
          Please provide more information:
          - Device(s) you are testing on and iOS version. I know you are using iOS 10, but is it one of the betas or the GM?
          - Have you recompiled your app?
          - Are you using PGB or the CLI?
          - What version of Phonegap are you using? What version of the cordova-ios platform are you using?
          - How are you loading and rendering your SVG images? Code would help.
          - Are the apps release builds or test builds? If the latter, debug with Safari and see if anything pops up on the console.
          Thoughts:
          - Reduce to the smallest code that reproduces the problem. I'd start with a simple app that just renders a single SVG image. If that works, try multiple SVG images. Then add styling... etc. When things break, you should have a better idea of the trigger.
          - iOS 10 has tightened the CSP (content-security-policy) meta tag a bit. Depending on how you load & render SVGs, perhaps you're falling afoul of this.
          - Try using WKWebView (if you can; it's not a drop-in replacement and has its own issues) and see if the issue goes away.
          • 2. Re: iOS10 and SVG image problem
            ShazronAbdullah Adobe Employee
            More information needed. Are you loading it locally or remote? How are you loading it (embedded or img tag)?
            I did a quick test, using an <img> tag to a local file in my app package, I could load a SVG file in iOS 10 GM (to both the Simulator and Device)
            • 3. Re: iOS10 and SVG image problem
              cemshid Level 1
              I'm trying to load it locally via img tag. I can verify that, the path is correct
              I cannot see the image when I access the project on PhoneGap Mobile app.
              • 4. Re: iOS10 and SVG image problem
                Can you share an example that illustrates the problem? Have you tried another SVG file -- perhaps there's something up with the particular SVG image you're loading?
                Also: what do you mean by "PhoneGap Mobile app" -- are you using PhoneGap Desktop/Developer apps?
