5 Replies Latest reply on Sep 19, 2016 1:34 AM by Heimdaal
    Trying to get path of running JSX ($.filePath not working)
    Heimdaal Level 1
      I'm trying to get the location of the directory of the current script (main.jsx of my panel).
      I've tried using $.filePath without success...
      alert($.filePath);
      Returns undefined or an int
      var thisFile = new File($.fileName);
      alert(thisFile);
      Returns /c/Program%20Files/Adobe/Adobe%20Photoshop%20CC%202015
      var thisFile  = new File($.fileName).parent;
      alert(thisFile .fsName);
      Returns C:\Program Files\Adobe\Adobe Photoshop CC 2015
      What am I doing wrong?
      I need to get the path of the running script file so I can do .parent to get it's folder name, and from there get a sibling folder name where I have some stuff to retrieve. I'm running this in my main.jsx -file.
        • 1. Re: Trying to get path of running JSX ($.filePath not working)
          Pedro Cortez Marques Level 3
          Hi
          Using this
          File($.fileName).fsName
          you'll get  C:\Program Files\Adobe\Adobe Photoshop CC 2015\[scriptName.jsx]
          Using this
          decodeURI(File($.fileName))
          you'll get  /c/Program Files/Adobe/Adobe Photoshop CC 2015/[scriptName.jsx]
          Or, to get the folder:
          Using this
          File($.fileName).parent.fsName
          Using this
          decodeURI(File($.fileName).parent)
          You only need to use decodeURI() if not getting fsName, because fsName result is always decoded.
          • 2. Re: Trying to get path of running JSX ($.filePath not working)
            Heimdaal Level 1
            It's not working.
            Using your first example, I get:
            C:\Program Files\Adobe\Adobe Photoshop CC 2015\526
            then the second time I use it I get
            C:\Program Files\Adobe\Adobe Photoshop CC 2015\527
            The number increments for each time I run the function where I have alert(File($.fileName).fsName);
            • 3. Re: Trying to get path of running JSX ($.filePath not working)
              Hi
              Oh I have noticed just now that you are not putting your scripts in the scripts folder.
              They should be here:
              C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Scripts\
              I have put a script jsx file in the photoshop scripts folder containing this:
              and the alert came up with this:
              C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Scripts\myScriptFile.jsx
              • 4. Re: Trying to get path of running JSX ($.filePath not working)
                Heimdaal Level 1
                That is correct - my scripts are located in the main.jsx of my panel.
                c:\Users\martin.dahlin\AppData\Roaming\Adobe\CEP\extensions\com.myCustomPanel\jsx\main.jsx
                So I guess that the $.fileName function is rather dumb and not really working with panels. If this is indeed the case then is there another way of getting the path to the panel and/or script???
                Also: I tried running alert($.fileName); in jsh* and then I got the correct path to the script So it appears that you only get this weird result when executing scripts from a panel.
                *(a javascript shell. Google for Photoshop xtools and you'll find it - it's super-useful!)
                • 5. Re: Trying to get path of running JSX ($.filePath not working)
                  Heimdaal Level 1
                  Found the solution!
                  By running this code in the javascript file of your extension you will get the path:
                  var csInterface = new CSInterface();
                  var extensionRoot = csInterface.getSystemPath(SystemPath.EXTENSION) + "/jsx/";
                  alert(extensionRoot);
                  Credits goes to Davide Barranca
