1 Reply Latest reply on Sep 14, 2016 11:50 PM by Nanaky
    Unable to return books to library - says I need to authorize computer first but computer is already authorized
    ginabits
      I cannot use Adobe Digital Editions on my home computer since it was upgraded to Windows 10. I had already downloaded books to the library that I want to return and it wont let me do it because it says the computer is not authorized but it already is. I tried erasing the authorization and redoing it to no avail
        • 1. Re: Unable to return books to library - says I need to authorize computer first but computer is already authorized
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
