0 Replies Latest reply on Sep 14, 2016 7:15 AM by ChocoBeast
    .replace() changes following paragraph style
    ChocoBeast Level 1
      I'm having an issue with a script. I have one version that converts numbers in a specific paragraph style to words, and it works just fine. I've gotten the corresponding version that converts words to numbers to work, but with one problem: it also changes the following paragraph to the same style, even though it doesn't do this in the other version. Am I missing something here?
      Note that I do plan to merge these into the same script - they're just separate right now for testing purposes.
      Numbers to Words (no issues)
      #target "InDesign"
      function getParagraphStyle(styleName, targetDoc) {
        if (targetDoc == null) {
        targetDoc = app.activeDocument;
        if (targetDoc.paragraphStyles.itemByName(styleName) != null) {
        return targetDoc.paragraphStyles.itemByName(styleName);
        } else {
        var max = targetDoc.paragraphStyleGroups.count()
        for (var i = 0; i < max; i++) {
        if (targetDoc.paragraphStyleGroups[i].paragraphStyles.itemByName(styleName) != null) {
        return targetDoc.paragraphStyleGroups[i].paragraphStyles.itemByName(styleName);
      function main(options) {
        if (options[0] == "Numbers") {
        if (options[1] == "Words") {
        for (var i = 0; i < options[2].length; i++) {
        parseNumbers(options[2][i], getActiveStory(), ChangecaseMode.TITLECASE);
        } else if(options[1] == "Roman Numerals") {
        // STILL NEED TO WRITE THIS FUNCTION
        alert("This doesn't work yet. Sorry.");
        } else if (options[0] == "Words") {
        if (options[1] == "Numbers") {
        } else if (options[1] == "Roman Numerals") {
        } else if (options[0] == "Roman Numerals") {
        } else if (options[1] == "Words") {
      function parseNumbers(targetStyle, targetStory, capitalization) {
        var targets = itemsByParagraphStyle(targetStyle, targetStory);
        var tempString, newString;
        for (var i=targets.length-1; i > -1; i--) {
        try {
        tempString = parseInt (targets[i].contents.match(/\d+/)[0]);
        } catch(e) {
        continue;
        newString = spellNumber(tempString);
        if (capitalization = ChangecaseMode.TITLECASE) {
        newString = capitalize(newString);
        } else if (capitalization = ChangecaseMode.UPPERCASE) {
        newString = newString.toUpperCase();
        } else if (capitalization = ChangecaseMode.LOWERCASE) {
        newString = newString.toLowerCase();
        targets[i].contents = targets[i].contents.replace(tempString, newString);
        return true;
      function itemsByParagraphStyle(style, targetStory) {
        resetFindPrefs();
        app.findTextPreferences.appliedParagraphStyle = getParagraphStyle(style);
        return targetStory.findText();
      function spellNumber(num) {
        var word;
        num = num.toString();
        if (num.length == 1) {
        word = wordForNumber(num);
        } else if(num.length == 2) {
        if (parseInt(num) > 19) {
        var num1 = num.charAt(0) +"0";
        var num2 = num.charAt(1);
        word = wordForNumber(num1) + "-" + wordForNumber(num2);
        } else if (parseInt(num) < 20) {
        return word;
      function wordForNumber(num) {
        var word;
        switch(num) {
        case "0":
        word = "";
        break;
        case "1":
        word = "one";
        break;
        case "2":
        word = "two";
        break;
        case "3":
        word = "three";
        break;
        case "4":
        word = "four";
        break;
        case "5":
        word = "five";
        break;
        case "6":
        word = "six";
        break;
        case "7":
        word = "seven";
        break;
        case "8":
        word = "eight";
        break;
        case "9":
        word = "nine";
        break;
        case "10":
        word  = "ten";
        break;
        case "11":
        word = "eleven";
        break;
        case "12":
        word = "twelve";
        break;
        case "13":
        word = "thirteen";
        break;
        case "14":
        word = "fourteen";
        break;
        case "15":
        word = "fifteen";
        break;
        case "16":
        word = "sixteen";
        break;
        case "17":
        word = "seventeen";
        break;
        case "18":
        word = "eighteen";
        break;
        case "19":
        word = "nineteen";
        break;
        case "20":
        word = "twenty";
        break;
        case "30":
        word = "thirty";
        break;
        case "40":
        word = "forty";
        break;
        case "50":
        word = "fifty";
        break;
        case "60":
        word = "sixty";
        break;
        case "70":
        word = "seventy";
        break;
        case "80":
        word = "eighty";
        break;
        case "90":
        word = "ninety";
        break;
        return word;
      function resetFindPrefs(){
          app.findTextPreferences = null;
          app.changeTextPreferences = null;
      function capitalize(string) {
        var strings = string.split(" ");
        for (var i=0; i < strings.length; i++) {
        strings[i] = strings[i].charAt(0).toUpperCase() + strings[i].substr(1);
        return strings.join(" ");
      // BUILD USER INTERFACE
      function displayWindow() {
        var userOptions;
        var win = new Window("dialog", 'Adjust Number Style', [0,0,280,234], );
        with(win){
        win.ddFrom = add( "dropdownlist", [50,5,150,27], undefined, {items: ['Numbers','Words','Roman Numerals'], } );
        win.sText1 = add( "statictext", [5,7,50,27], 'Convert' );
        win.sText2 = add( "statictext", [155,7,170,27], 'to' );
        win.ddTo = add( "dropdownlist", [175,5,275,27], undefined, {items: ['Numbers','Words','Roman Numerals'], } );
        win.sText3 = add( "statictext", [5,32,110,52], 'for text styled as:' );
        win.tStyles = add( "listbox", [5,52,275,202], undefined, {multiselect: true} );
        win.butRun = add( "button", [130,207,200,229], 'Run', {name: 'OK', } );
        win.butCancel = add( "button", [205,207,275,229], 'Cancel', {name: 'Cancel', } );
        win.center();
        // ADD EVENT HANDLERS
        win.onShow = function() {
        var styleCount, styleGroupCount, itemHolder;
        styleCount = app.activeDocument.paragraphStyles.count();
        for (var i = 0; i < styleCount; i++) {
        win.tStyles.add("item", app.activeDocument.paragraphStyles[i].name);
        styleGroupCount = app.activeDocument.paragraphStyleGroups.count();
        for (var i = 0; i < styleGroupCount; i++) {
        itemHolder = win.tStyles.add("item", app.activeDocument.paragraphStyleGroups[i].name);
        itemHolder.enabled = false;
        styleCount = app.activeDocument.paragraphStyleGroups[i].paragraphStyles.count();
        for (var k = 0; k < styleCount; k++) {
        win.tStyles.add("item",app.activeDocument.paragraphStyleGroups[i].paragraphStyles[k].name );
        win.ddFrom.selection = win.ddFrom.items[0];
        win.ddTo.selection = win.ddTo.items[1];
        win.butRun.onClick = function () {
        var from = win.ddFrom.selection.text;
        var to = win.ddTo.selection.text;
        var styles = [];
        var selectionCount;
        selectionCount = win.tStyles.selection.length;
        for (i = 0; i < selectionCount; i++) {
        styles.push(win.tStyles.selection[i].text);
        userOptions = [from, to, styles];
        win.close(1);
        if (win.show() == 1) {
        return userOptions;
        } else {
        return false;
      var userOptions = displayWindow();
      if (userOptions) main(userOptions);
      Words to Numbers (paragraph style issue)
      #target "InDesign"
        } else {
        parseWords(options[2][i], getActiveStory());
      function parseWords(targetStyle, targetStory) {
        var tempStr, tempPos, tempString, newString;
        try {
        tempStr = targets[i].contents.toString();
        tempPos = tempStr.search(/\r/);
        tempString = tempStr.substring(0,tempPos);
        } catch(e) {
        continue;
        newString = convertWord(tempString);
        return true;
        resetFindPrefs();
      function convertWord(word) {
        var num;
        word = word.toString();
        var numberOfSpaces = (word.match(/ /g) || []).length;
        var numberOfHyphens = (word.match(/-/g) || []).length;
        if (numberOfSpaces == 0 && numberOfHyphens == 0) { // no space, no hyphen
        num = numberForWord(word);
              } else if (numberOfSpaces == 1 && numberOfHyphens == 0) { // one space, no hyphen
                  var tempParse = word.split(" ");
                  var word1 = tempParse[0];
                  var word2 = tempParse[1];
                  num = word1 + " " + numberForWord(word2);
              } else if (numberOfSpaces == 0 && numberOfHyphens == 1) { // no space, hyphen
                  var tempParse = word.split("-");
                  num = numberForWord(word1).substring(0,1) + numberForWord(word2);
              } else if (numberOfSpaces == 1 && numberOfHyphens == 1) { // one space, hyphen
                  var tempParse2 = tempParse[1].split("-");
                  var word1 = tempParse2[0];
                  var word2 = tempParse2[1];
                  num = tempParse[0] + " " + numberForWord(word1).substring(0,1) + numberForWord(word2);
              } else if (numberOfSpaces > 1 && numberOfHyphens == 1) { // multiple spaces, hyphen
                  var tempParse = word.lastIndexOf(" ");
                  var tempParseSpace = word.substring(0,tempParse);
                  var tempParseSpaceSplit = word.substring(tempParse);
                  var tempParse2 = tempParseSpaceSplit.split("-");
                  var word1 = tempParse2[0].substring(1);
                  num = tempParseSpace + " " + numberForWord(word1).substring(0,1) + numberForWord(word2);
              } else if (numberOfSpaces > 1 && numberOfHyphens == 0) { // multiple spaces, no hyphen
                  var word1 = word.substring(0,tempParse);
                  var word2 = tempParseSpaceSplit.substring(1);
          else {
              num = word;
        return num;
      function numberForWord(word) {
        var num;
        switch(word.toLowerCase()) {
        case "one":
        num = "1";
        break;
        case "two":
        num = "2";
        break;
        case "three":
        num = "3";
        break;
        case "four":
        num = "4";
        break;
        case "five":
        num = "5";
        break;
        case "six":
        num = "6";
        break;
        case "seven":
        num = "7";
        break;
        case "eight":
        num = "8";
        break;
        case "nine":
        num = "9";
        break;
        case "ten":
        num = "10";
        break;
        case "eleven":
        num = "11";
        break;
        case "twelve":
        num = "12";
        break;
        case "thirteen":
        num = "13";
        break;
        case "fourteen":
        num = "14";
        break;
        case "fifteen":
        num = "15";
        break;
        case "sixteen":
        num = "16";
        break;
        case "seventeen":
        num = "17";
        break;
        case "eighteen":
        num = "18";
        break;
        case "nineteen":
        num = "19";
        break;
        case "twenty":
        num = "20";
        break;
        case "thirty":
        num = "30";
        break;
        case "forty":
        num = "40";
        break;
        case "fifty":
        num = "50";
        break;
        case "sixty":
        num = "60";
        break;
        case "seventy":
        num = "70";
        break;
        case "eighty":
        num = "80";
        break;
        case "ninety":
        num = "90";
        break;
        default:
        num = word;
        break;
        return num;
        var userOptions;
        with(win){
        win.center();
        win.ddFrom.selection = win.ddFrom.items[1];
        win.ddTo.selection = win.ddTo.items[0];
        var styles = [];
        var selectionCount;
        win.close(1);
        return userOptions;
        } else {
        return false;
