4 Replies Latest reply on Sep 16, 2016 12:04 AM by George_Johnson
    Need help creating custom calculation script in Adobe Acrobat Pro
    laurens6820332
      I am creating a fillable form for a college midterm grading rubric. I have the totals adding up, getting divided by 15 (number of questions) to give me my average. Then, I have a table with corresponding percentages based on what the average score is. I need to create a custom calculation script to do an if/then situation. "If your average score is 1.9, then your percent is 97%". However, when I divide the total by 15 I am often left with a number that has many decimals. I really don't want to have to go in and type in every possible decimal point in order for the percentage calculations to come out correctly. Is there a way to do a if/else if situation like "If average is between 1.7 and 1.79, then your percentage is 91%"?
      Hopefully this makes sense and thank you in advance for any suggestions!
        • 1. Re: Need help creating custom calculation script in Adobe Acrobat Pro
          You have to round the result. This can be done using the "Format" option of "Number" and specifying the number of zeros. This will round up. You could also force the value of the field to the rounded value using the "util.printf" method. This too will round up. You can use the Math.ceil and Math.floor methds to not round but go tot the nest larger value or truncate the value.
          • 2. Re: Need help creating custom calculation script in Adobe Acrobat Pro
            George_Johnson MVP & Adobe Community Professional
            Yes, there is a way to do that using an if/else if/else statement, no rounding needed. If you post your current script I can suggest a revision.
            • 3. Re: Need help creating custom calculation script in Adobe Acrobat Pro
              laurens6820332 Level 1
              Hi George,
              This is the current script I'm working with. It originated on something that I was dividing by 10 instead of 15. That made the decimal count go down significantly. For example: if my Average_Score is 1.7222222222 I would need the output value to read as 91%.  Thank you!
              var v = this.getField("Average_Score").valueAsString;
              if (v=="2") event.value = "100%";
              else if (v=="1.95") event.value = "100%";
              else if (v=="1.9") event.value = "97%";
              else if (v=="1.85") event.value = "97%";
              else if (v=="1.8") event.value = "94%";
              else if (v=="1.75") event.value = "94%";
              else if (v=="1.7") event.value = "91%";
              else if (v=="1.65") event.value = "91%";
              else if (v=="1.6") event.value = "88%";
              else if (v=="1.55") event.value = "88%";
              else if (v=="1.5") event.value = "85%";
              else if (v=="1.45") event.value = "85%";
              else if (v=="1.4") event.value = "82%";
              else if (v=="1.35") event.value = "82%";
              else if (v=="1.3") event.value = "79%";
              else if (v=="1.25") event.value = "79%";
              else if (v=="1.2") event.value = "76%";
              else if (v=="1.15") event.value = "76%";
              else if (v=="1.1") event.value = "73%";
              else if (v=="1.05") event.value = "73%";
              else if (v=="1") event.value = "70%";
              else if (v=="0.95") event.value = "70%";
              else if (v=="0.9") event.value = "63%";
              else if (v=="0.85") event.value = "63%";
              else if (v=="0.8") event.value = "56%";
              else if (v=="0.75") event.value = "56%";
              else if (v=="0.7") event.value = "49%";
              else if (v=="0.65") event.value = "49%";
              else if (v=="0.6") event.value = "42%";
              else if (v=="0.55") event.value = "42%";
              else if (v=="0.5") event.value = "35%";
              else if (v=="0.45") event.value = "35%";
              else if (v=="0.4") event.value = "28%";
              else if (v=="0.35") event.value = "28%";
              else if (v=="0.3") event.value = "21%";
              else if (v=="0.25") event.value = "21%";
              else if (v=="0.2") event.value = "14%";
              else if (v=="0.15") event.value = "14%";
              else if (v=="0.1") event.value = "7%";
              else if (v=="0.05") event.value = "7%";
              else if (v=="0") event.value = "0%";
              • 4. Re: Need help creating custom calculation script in Adobe Acrobat Pro
                Try something like this:
                // Get the field value, as a number
                var v = +getField("Average_Score").value;
                // Set this field value based on the number
                if (v >= 1.95) event.value = "100%";
                else if (v >= 1.85 && v < 1.95) event.value = "97%";
                else if (v >= 1.75 && v < 1.85) event.value = "94%";
                // etc.
