9 Replies Latest reply on Sep 18, 2016 4:30 PM by Vfxvenkat98
    save files in a done folder
    Vfxvenkat98 Level 1
      hi,
      i need to save the new .jpg images in same location of the active document in a seperate folder called Done folder.
      Right now this script saved the jpegs  in same location without a folder
      Kindly help me on this script
      #target photoshop;
      if (app.documents.length > 0) {
          var thedoc = app.activeDocument;
          // getting the name and location;
          var docName = thedoc.name;
          if (docName.indexOf(".") != -1) {
              var basename = docName.match(/(.*)\.[^\.]+$/)[1];
          } else {
              var basename = docName;
          // getting the location, if unsaved save to desktop;
          try {
              var docPath = thedoc.path}
          catch (e) {
              var docPath = "~/Desktop"
          var layerSets_ = app.activeDocument.layerSets;
          for (var a =0; a < layerSets_.length; a++) {
              // turn all layerSets invisible
              for (var b =0; b < layerSets_.length; b++) {
                  layerSets_[b].visible = false;
              layerSets_[a].visible = true;
              // jpg options;
              var jpegOptions = new JPEGSaveOptions();
              jpegOptions.quality = 12;
              jpegOptions.embedColorProfile = true;
              jpegOptions.matte = MatteType.NONE;
              //save jpg in layerset name:
              thedoc.saveAs(new File(docPath+'/'+layerSets_[a].name+'.jpg'),jpegOptions,true);
              //thanks to xbytor;
        • 1. Re: save files in a done folder
          Pedro Cortez Marques Level 3
          Hi!
          Just change this:
          with this:
          var outFolder = Folder(docPath+'/Done');
          if (!outFolder.exists) outFolder.create();
          thedoc.saveAs(new File(outFolder +'/'+layerSets_[a].name+'.jpg'),jpegOptions,true);
          With folders, you have to creat them before using them to put files. If you don't, the file will not be saved.
          Hope it helps.
          • 2. Re: save files in a done folder
            Vfxvenkat98 Level 1
            Thanks Marques
            but i also want that files in .tif format also in TIFF
            how to replace the .jpg options to .tiff options ??
            • 3. Re: save files in a done folder
              Vfxvenkat98 Level 1
              So that save my layersets into TIFF files into TIFF FOLDER
              • 4. Re: save files in a done folder
                Hi, you have that answered on other posts on this forum.
                But I send you one of possibilities:
                #target photoshop;
                    } else {
                    try {
                    catch (e) {
                        // TIFF
                        SaveTiff(File(docPath+'/'+layerSets_[a].name+'.TIFF'));
                function SaveTiff(saveFile) {
                    tiffSaveOptions = new TiffSaveOptions();
                    tiffSaveOptions.alphaChannels = false;
                    tiffSaveOptions.annotations = false;
                    tiffSaveOptions.byteOrder = ByteOrder.IBM;
                    tiffSaveOptions.embedColorProfile = true;
                    tiffSaveOptions.imageCompression = TIFFEncoding.NONE;
                    tiffSaveOptions.layerCompression = LayerCompression.RLE;
                    tiffSaveOptions.layers = true;
                    tiffSaveOptions.saveImagePyramid = false;
                    tiffSaveOptions.spotColors = false;
                    tiffSaveOptions.transparency = true;
                    activeDocument.saveAs(saveFile, tiffSaveOptions, true, Extension.LOWERCASE);
                • 5. Re: save files in a done folder
                  Vfxvenkat98 Level 1
                  but this script saves all the layersets in everydocument document but i need only one layerset in one document
                  • 6. Re: save files in a done folder
                    Vfxvenkat98 Level 1
                    it should take only one layergroup from the main document and save it along with background  layer
                    • 7. Re: save files in a done folder
                      Do you mind to explain what you want all at once, please?
                      I cant't guess what layer group you want to save. Do you want the script to as you if there are more than one?
                      • 8. Re: save files in a done folder
                        Vfxvenkat98 Level 1
                        Right now the script will export each layer group into jpeg .so it will process what are all layer groups available  in the main document.
                        now the same i need those files in .TIFF format in a separate folder Done 2
                        i want each layer-group in the main document to be saved as a different files in done folder along with background layer and that layer group of main document.
                        For example
                        i opened my Master.tiff document in Photoshop.
                        It is having multiple layer sets like 1,2,3,4,5.
                        Now i want to export all these five layer sets into 5 .tiff files along with same background.
                        • 9. Re: save files in a done folder
                          Vfxvenkat98 Level 1
                          #target photoshop
                          function main(){
                          if(!documents.length) return;
                          var doc = activeDocument;
                          var oldPath = activeDocument.path;
                          for(var a=0;a<doc.layerSets.length;a++){
                          activeDocument.activeLayer = activeDocument.layers.getByName(doc.layerSets[a].name);
                          dupLayers();
                          // activeDocument.mergeVisibleLayers();// Merge visible layer
                          activeDocument.trim(TrimType.TRANSPARENT,true,true,true,true);
                          var saveFile= File(oldPath +"/"+doc.layerSets[a].name +".psd");
                          SavePSD(saveFile);
                          app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
                          main();
                          function dupLayers() {
                              var desc143 = new ActionDescriptor();
                                  var ref73 = new ActionReference();
                                  ref73.putClass( charIDToTypeID('Dcmn') );
                              desc143.putReference( charIDToTypeID('null'), ref73 );
                              desc143.putString( charIDToTypeID('Nm  '), activeDocument.activeLayer.name );
                                  var ref74 = new ActionReference();
                                  ref74.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                              desc143.putReference( charIDToTypeID('Usng'), ref74 );
                              executeAction( charIDToTypeID('Mk  '), desc143, DialogModes.NO );
                          function SavePSD(saveFile){
                          psdSaveOptions = new PhotoshopSaveOptions();
                          psdSaveOptions.embedColorProfile = true;
                          psdSaveOptions.alphaChannels = true;
                          activeDocument.saveAs(saveFile, psdSaveOptions, true, Extension.LOWERCASE);
                          In the above script it duplicates every layer and save it as  psd without background layer but i want it saved as TIFF along with same backgroud  for all documents in a seperate done folder
                          anyone help me on this to complete this cript
