3 Replies Latest reply on Sep 16, 2016 2:00 AM by Loic.Aigon
    Scripting ♀ 9mm ♂ 7mm with character styles
    robertwhyte
      I am writing a field guide where each photo has a caption in Myriad Pro part of which is ♀ 9mm ♂ 7mm (the actual measurements in mm vary). Because the font doesn't seem to support the ♀  ♂ characters I have a character style +Arial + Bold
      This works fine. The bold is not necessary, it just makes the style easier to see if applied to a stray text instead of those male and female symbols.
      I use "type it for me" to enter ♀ 9mm ♂ 7mm with a shortcut. ♀ 9mm ♂ 7mm
      Is there a scripting (or other) way to to this so it can be done in one go and tied to a short cut?
      It would seem to be something like:
      type ♀
      select ♀
      apply character style "MFsymbols"
      type space
      select space
      apply character style "None"
      type 9mm space
      type ♂
      select ♂
      type space
      select space
      type 7mm space
        • 1. Re: Scripting ♀ 9mm ♂ 7mm with character styles
          Stefan Rakete Level 2
          Here is a start with a script
          // place your cursor in a textFrame and have Arial as font
          // The Glyph ID you can find in the Glyph palette
          // Select an Insertion Point
          var CHARACTER_FEMALE = "\u2640";
          var CHARACTER_MALE = "\u2642";
          var curSelection = app.selection[0];
          if (curSelection.constructor.name == "InsertionPoint") {
              curSelection.contents =  CHARACTER_FEMALE;
              //curSelection.contents =  CHARACTER_MALE;
          Thanks Stefan
          • 2. Re: Scripting ♀ 9mm ♂ 7mm with character styles
            Obi-wan Kenobi Level 5
            If I understand well what you mean, apply a Keyboard shortcut to this script and try:
            CS = app.activeDocument.selection[0].insertionPoints[0].appliedCharacterStyle;
            app.activeDocument.selection[0].insertionPoints[-1].appliedCharacterStyle = "MFsymbols";
            app.activeDocument.selection[0].insertionPoints[-1].contents = "\u2640";
            app.activeDocument.selection[0].insertionPoints[0].appliedCharacterStyle = CS;
            app.activeDocument.selection[0].insertionPoints[-1].contents = " 9mm ";
            app.activeDocument.selection[0].insertionPoints[-1].contents = "\u2642";
            app.activeDocument.selection[0].insertionPoints[-1].contents = " 7mm ";
            [not tested]
            • 3. Re: Scripting ♀ 9mm ♂ 7mm with character styles
              Loic.Aigon Adobe Community Professional
              Have you considered creating a font of yours with InDyFont ? You could pick the default font you want like Myriad and redefine shape for the \u2640 et \u2642 characters so they match the pictos of Male & Female.
              No scripting here but something you could easily reuse somewhere else.
              Indiscripts :: IndyFont | Build OpenType Fonts from within InDesign!
              FWIW
              Loic
